Tires: Ouch!!!!
Old Apr 18, 2002 | 08:57 PM
SeansVette's Avatar
SeansVette
Cruising
Default Tires: Ouch!!!!
Time to replace the two rear tires. The CHEAPEST place I found was $805.00 for both rear tires (and ballance & allignment) after tax. Is there a cheaper way to go? I'm even comtemplating rolling the dice by using non-runflats.
:cry
Old Apr 18, 2002 | 09:05 PM
Viprklr's Avatar
Viprklr
Default Re: Tires: Ouch!!!! (SeansVette)
Check the C5 for sale section. I see runflats on there a lot, some even new, for a lot less. I went with a non-runflat recently and couldn't be happier. I'll just take a patch kit and air compressor with me on long trips. :cheers:
Old Apr 18, 2002 | 09:10 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I got 4 Firestone runflats thru local dealer $1090 out the door mounting,balancing etc...
Old Apr 18, 2002 | 09:50 PM
pjazz's Avatar
pjazz
C6 of Year Winner (performance mods) 2019
I don't know if ones in Cali, but Discount Tire is pretty reasonable.
Old Apr 18, 2002 | 09:56 PM
Z06 Quin's Avatar
Z06 Quin
Default Re: Tires: Ouch!!!! (pjazz)
try tirerack or discounttiredirect.......you won't be sorry....
Old Apr 19, 2002 | 01:17 AM
LTD's Avatar
LTD
jesus, at least check out the tirerack or discount tire direct. no need to throw money away. also, i think tirerack can heat cycle those babies on the cheap.
Old Apr 19, 2002 | 09:48 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
tire rack has the rears for 299 each... shipping is around 20 dollars for both
Old Apr 19, 2002 | 10:11 AM
JoeCon's Avatar
JoeCon
There is no need for run flats, Its up to you. There are many other more cost efective tires on the market. You should expect to pay $75.00 per mount and balance.
Old Apr 19, 2002 | 12:27 PM
lostsoulny's Avatar
lostsoulny
Default Re: Tires: Ouch!!!! (JoeCon)
i got quoted 345 each mounted and balanced.
Old Apr 19, 2002 | 08:35 PM
Evil-Twin's Avatar
Evil-Twin
Default Re: Tires: Ouch!!!! (lostsoulny)
I payed 335 mounted and balanced at a local shop.. for the rears and 260 for the fronts
50 dollars for a 4 wheel aignment
To Tires: Ouch!!!!
