gas gauge not working
Old Apr 24, 2011 | 02:30 PM
mfdboating's Avatar
mfdboating
Default gas gauge not working
I have a 2000 coupe, manual with 19k miles, while cruising today, the instrument panel read" check gauges", the gas gauge had gone to E. I had just over a half of a tank, and put another 5 gallons in after this happened. When I start the car the gas guage needle goes from E to F as it did before this problem but then back to E, thus prompting the "check guages" warning.
Can anyone tell me what to look for and possible where a wire or something may have come loose.
All other electronic warngins and gauges are working fine.
Thanks for your help.
Old Apr 24, 2011 | 02:37 PM
01_torch_red_vette's Avatar
01_torch_red_vette
start running some techron through it when you fill up. most likely have some buildup on the fuel sending unit causing it to give a false empty indication. you should be able to go in to your codes and delete it and have the fuel guage come back up
Old Apr 24, 2011 | 02:40 PM
383LPE's Avatar
383LPE
+1, works
Old Apr 24, 2011 | 02:53 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
This is a common issue. Techron usually works to resolve it. Pull your codes and you'll find a code for it but usually just shutting down and restarting, it'll work. There is a firmware update available which may also be of benefit.
Old Apr 24, 2011 | 08:22 PM
ricknyc23's Avatar
ricknyc23
Old Apr 24, 2011 | 09:11 PM
mfdboating's Avatar
mfdboating
Default codes
Sorry to sound so ignorant, but when you guys say "codes" do I need to have a servoce tech connect to the car, or is this something I can check myself? I will get the Techron tomm and give that a try. Thanks for all the responses though, appreciate it.
Old Apr 24, 2011 | 11:57 PM
byronhunter's Avatar
byronhunter
COODES, read post #4 in this thread.
http://forums.corvetteforum.com/c5-t...ir-my-zo6.html
Also, make sure you get Techron Concentrate Plus.
Old Apr 25, 2011 | 08:17 AM
dgrant3830's Avatar
dgrant3830
As byronhunter linked for you, the car's DIC in all C-5's has the ability to display all of the car's codes from all of the computers. Its a powerful tool and know that on the C-6's, they took this out
Old Apr 25, 2011 | 10:43 AM
mikesvette1's Avatar
mikesvette1
i put techron in mmy fuel tank and it wasn't soon after it fixed the problem, the mechanic told me it would take about $1000 dollars to fix but now works fine thanks alot
Old Apr 25, 2011 | 01:12 PM
photonhunter's Avatar
photonhunter
Active Streak: 90 Days
You could have easily found the answers to your two questions by looking at the stickies or by reading one of the hundreds of posts that a search would have turned up.
dan
To gas gauge not working
