Fuel Filter location
Old Apr 25, 2011 | 07:20 AM
Neatnic's Avatar
Neatnic
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '07-'09
Default Fuel Filter location
Is there an "in line" fuel filter on my 2004 C5 vert? or just the filter in the gas tank?
Old Apr 25, 2011 | 07:46 AM
lucky131969's Avatar
lucky131969
In the tank.
Old Apr 25, 2011 | 08:45 AM
lavery48's Avatar
lavery48
My C5 1998 has an inline filter.
Old Apr 25, 2011 | 08:48 AM
lucky131969
.....and the OP has a 2004.....
Old Apr 25, 2011 | 09:54 AM
GeneT's Avatar
GeneT
Doesn't the 2004 have the same filter that a 2002 does ??
If so, then it doesn't get much more "in-line" than that.
I just changed mine. Takes less than 1/2 hour.
http://www.cajundude.com/fuelfilter.htm
Old Apr 25, 2011 | 10:00 AM
lucky131969
Nope.
Old Apr 25, 2011 | 10:35 AM
GeneT's Avatar
GeneT
Originally Posted by lucky131969
Nope.
I'm just saying, from looking at the part online, and it says 1999-2004
but I can't say for sure what fits what model, just that
mine is a '02. I'd like to have an '04, or an '06, but I'm happy with my '02.
Old Apr 25, 2011 | 10:38 AM
lucky131969
I've seen it listed like that too.........not correct.
Old Apr 25, 2011 | 10:42 AM
GeneT's Avatar
GeneT
AND.....that's why we all check this great Corvette Forum !!
Old Apr 25, 2011 | 02:35 PM
DaBoz's Avatar
DaBoz
In the tank.
Old Apr 25, 2011 | 02:39 PM
Neatnic's Avatar
Neatnic
Cruise-In V Veteran
Cool, so it's in the tank and does not need to be changed until 100K so I have been told
Old Apr 25, 2011 | 02:46 PM
lucky131969
I've never seen anything written.....to that effect.
Old Apr 25, 2011 | 03:01 PM
DaBoz's Avatar
DaBoz
I just looked through my shop manual ('04) and found nothing about changing it...
There's a part number but it's nowhere in the scheduled maintenance.
FWIW
Old Apr 25, 2011 | 03:21 PM
Neatnic's Avatar
Neatnic
Cruise-In V Veteran
ok, thanks!
Old Jul 1, 2011 | 09:08 PM
SteveDoten's Avatar
SteveDoten
late 2003 and 2004 share the same fuel tanks, FFS, like the C6 with the pump/sender on top
Did that omit the fuel filter located on the frame rail?? I forget
Old Jul 1, 2011 | 09:21 PM
Z06supercharged's Avatar
Z06supercharged
03/04 fuel filter cant be changed period UNLESS you change out the fuel pump since its all together. The filter isn't sold separately. Another POS design by GM.
Here is .pdf file of the FFS system configuration/parts.
http://www.hessh.de/Corvette/FuelTankSystem.pdf
Old Jul 1, 2011 | 09:23 PM
SteveDoten's Avatar
SteveDoten
late 2003, beats changing the JFS on an F16 with 120 heat in AZ
To Fuel Filter location
