Mighty-Vac Bleeding Clutch - How To?
Old Apr 25, 2011 | 04:51 PM
Atok's Avatar
Atok
Default Mighty-Vac Bleeding Clutch - How To?
I bought a Mighty-Vac hoping I could use it to more easily change the fluid in my clutch system. I have a remote bleeder installed but when I attach the MV, crack the bleeder and apply vacuum I do not get any fluid. Should I be able to suck the fluid from the master cylinder by doing this?
Those of you with Might-Vacs what method do you use when bleeding the clutch system?
Old Apr 25, 2011 | 07:19 PM
Atok's Avatar
Atok
I got it. Had a leak at the bleeder fitting so it was sucking air.
Unbelievable how much black crud gets built up in the fluid. I use to do the ranger method every 6 months now this MV makes it a breeze.
Old Apr 26, 2011 | 12:59 AM
Ranger's Avatar
Ranger
Originally Posted by Ranger
Bleeding a Clutch Via an Installed Remote Bleeder
Courtesy of “wrencher,” a moderator on LS1Tech.com and a GM Tech by profession. Reproduced and edited with permission.
A remote bleeder and Mity-Vac are absolutely essential to making the clutch bleeding procedure a one-man operation.
Connect a Mity-Vac to the outlet on the remote bleeder. To ensure a tight seal, apply a little “sil-glide” to the threads on the bleeder
Next, start by draining the reservoir with a syringe. Refill with clean fluid.
Then proceed to pull a vacuum & pull the fluid in normal flow direction w/ the Mity-Vac brake fluid bleeding attachment.
Keep doing it till the fluid comes out clean. Make sure you keep the reservoir at the proper level throughout.
wrencher states: I usually keep an eye on the fluid color & flush by the look of it.
I drag race my car a lot. I flush before and after every track visit.
If I don’t, the pedal changes & I know it's flush time.
I do a fluid change & all is well again.
By following this routine, I’ve kept my master cylinder working correctly for 3-4 years now while doing a lot of racing.
Thanks to wrencher for the info.
Ranger
Ranger
Old Apr 26, 2011 | 06:13 AM
Atok's Avatar
Atok
Thanks Ranger.
What's your opinion of DOT5 silicon based fluid in our clutch systems? I know it's not good to mix DOT4 and DOT5 so I'm thinking it's not a good thing to do.
Old Apr 26, 2011 | 08:36 AM
Ranger's Avatar
Ranger
Originally Posted by Atok
Thanks Ranger.
Your hydraulics will be damaged by any silicone fluid, because it can't deal with moisture that inevitably enter the system. So you want to stay with DOT4, which is the spec brake fluid for all M.Y. Corvettes with a hydraulic clutch. Some fluids are marketed as "super" DOT4, but the differences are generally "marketing."
Ranger
Old Apr 26, 2011 | 12:28 PM
Last C5's Avatar
Last C5
Ranger
What about the new 5.1 fluids? Any advantage to them over my tried and true ATE Blue?
Old Apr 26, 2011 | 08:41 PM
Ranger's Avatar
Ranger
"5.1" is mostly marketing. Plenty of high-temp DOT4 brake fluids suitable for the clutch. ATE is a great brand. But the Blue is so dark it hides the darkening of the fluid, which is the "tell" for appearance of clutch dust that destroys the seals in the hydraulics. So for the clutch if the ATE brand is your choice, the Type-200 (amber color) is better; you can tell when the clutch dust arrives.
Ranger
To Mighty-Vac Bleeding Clutch - How To?
