Brake lights not working
Old Apr 26, 2011 | 03:46 PM
evillaveces's Avatar
evillaveces
2nd Gear
Default Brake lights not working
My C5 brake lights left and right are not working. The center one works. The turn signals work and the flashers work. They blink when unlock on the fob is pressed.
Any ideas
Old Apr 26, 2011 | 04:01 PM
lucky131969's Avatar
lucky131969
Any ideas
Have you checked for 12 volts at the connector, when the brake pedal is pressed?
Old Apr 26, 2011 | 04:08 PM
ecorse66's Avatar
ecorse66
Sounds like a bad brake light switch.
Dave T.
Old Apr 26, 2011 | 04:11 PM
lucky131969
Dave T.
There is only one contact in the stoplamp switch, and the third brake light is working.
Old Apr 26, 2011 | 05:07 PM
Mrgogo's Avatar
Mrgogo
I just had this very same issue. It turned out to be the flasher unit. Go thru all the normal stuff first. Bulbs, fuses, contacts, etc. If it comes down to the flasher unit, there is a step by step directions to do it. If I can do it, you can too. Good luck.
Old Apr 26, 2011 | 05:26 PM
evillaveces
2nd Gear
Thanks, Do you have a part number for the flasher unit?
Old Apr 26, 2011 | 08:13 PM
Mrgogo's Avatar
Mrgogo
No sorry. You'll probably have to go to the dealership for it. My local Chevy dealer charged 40.00. A bargin.
To Brake lights not working
