HELP automatic transmission questions
Old Apr 26, 2011 | 10:24 PM
gearbox's Avatar
gearbox
Default HELP automatic transmission questions
does anyone know if you can swap out a 2004 auto transmission and put into a 1997. I heard the trans will swap but may have problems with the torque tube fitting properly????
and its electronically controlled, would i have any issues there???
Please HELP.. thanks
also I looked online and the 2001-2004 bushing is 12mm holes and the 1997-1999 is 10mm is the bushing still the same size.
