So I recently picked up a c5 and im absolutely new to that era vette and ls1 motor. So i was wondering, would a new air intake, cam, and exhaust be a good combo for some cheap horsepower?
Pick up a service manual, shop around and perform the work yourself. That will save you and enormous amount of money.
thanks for the info, Is there a good cam available for the ls1 motor that runs good for a mostly stock vette.
For those suggesting a long tube header for "most bang for the buck" you may want to consider a cam swap instead.
Headers are great to improve upon the flow capabilities of the engine, but if you don't first change what controls how much airflow can occur you don't really need the headers.
Cam is worth power throughout the ENTIRE rpm range in a noticeable fashion, unlike headers or CIA.
Here's a link to a cam swap article. http://www.superchevy.com/technical/...en3/index.html
You may want to really ask yourself what it is that you are looking to achieve though. Is it really power that you want, or just the perception of power. A good exhaust sound, CIA, and tune would be the best for the latter.
most cams that are worth the effort & cost to install would need headers to realize their full potential
I agree that if you are planning alot of mods long term, you need to start with the headers and build up.... But.. If you're planning on just one cheap mod and nothing more then think of it like this..
Headers - 20-30hp gain
Cam without full potential due to no headers - 40hp ish ( more than that and itll get more expensive cause youll need better springs, pushrods, etc.. should get em anyway though for safety)
From my experience everything I do to my c5 costs about double what I paid to do on my c4, usually more..
I would go so far as to say that most cams that are worth the effort and cost to install would need CAI, HEADS & HEADERS to realize their full potential....now you're getting close to the cost of a supercharger.
Of course, then you'll get passed by a new ZR1 and you'll want to add heads, cam, and headers to the supercharger so that you can give them a bit of a surprise....and so goes the endless spiral of modding. IMO, there's no "cheap" power because it's like a gateway drug, it just makes you want MORE!
Also, lets say I go with a Vararam, Cam, and borla straight pipes (exhaust of my choice) what cam would I see most hp gains with just the Vararam and Straight pipes (dont think that the straight pipes will matter much).
yeah... i remember the days when i was scared i might break something if i played around under a hood
