ECBM plug contacts
Old Apr 30, 2011 | 02:08 PM
wwwFLA's Avatar
wwwFLA
Default ECBM plug contacts
I've removed the subject plug to track down my ABS DIC code and found only 6 of the 7 slots have contacts. Can anyone confirm that one is missing or is that correct? It is the third from the right on the lower set of contacts in the ECBM plug not the contacts on the module, that has 7 blades there.
If it is missing, any ideas to fashion a contact?
Thank you!
Old Apr 30, 2011 | 02:37 PM
wwwFLA's Avatar
wwwFLA
Thanks BC,I found your picture of the plug with the proper missing contact. Looks like I'll just hose it down with some contact cleaner and cross my fingers (again).
Thanks again Bill for all your stuff!
Old Apr 30, 2011 | 05:22 PM
Dave68's Avatar
Dave68
I had a C1242 code (bad ground) that was not because of bad chassis grounds. It was a bad ground connection at the connector. I simply unplugged and plugged each of the two connectors approx three times and viola, the code and warning lights never returned.
To ECBM plug contacts
