Bad Ballast - need replacement
Apr 30, 2011 | 06:15 PM
St. Jude Donor '05-'08
had a HID out today and took everything apart and found the ballast to be the problem.
Simple solution order a new ballast NOT. I cannot find the Philips XLD 912 ballast since it is discontinued.
So does anyone know of a replacement ballast that will work?
thanks
Bob
Apr 30, 2011 | 06:29 PM
Apr 30, 2011 | 07:02 PM
Quote:
Originally Posted by
Jnape
you click on add to cart and nothing happens
I rather replace with something new just in case the other side goes out I dont want to go through this again.
Thanks for trying....
May 1, 2011 | 06:31 PM
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Just a FYI for anyone else looking the 912 was replaced by XLD 988. The supplier of the ACAs tell me these will be replaced soon also.
Mar 18, 2014 | 10:18 AM
JW@JWMotoring.com
Do you know if there is a sutiable replacement for the XLD912 and where I can find one?
Mar 18, 2014 | 10:50 AM
Cruise-In IX Veteran
Not sure about your situation, but I have found that more often then not the new part will have different connectors. I think it is a conspiracy to get you to buy a whole new kit.
Mar 18, 2014 | 12:09 PM
streamliner
I was told back in 2011 that the XLD988 replaced it. I Googled XLD988, and still found some for sale.
I can't guarantee it will work;that's just what I was told by the company that took over the ACA production. I'd check your connections and compare.
Mar 23, 2014 | 02:46 PM
JW@JWMotoring.com
FYI I decided to upgrade so now I have a spare (used) XLD 912 if you run across anyone who needs one. Thanks for your help.
912 ,
bad ,
ballast ,
ballest ,
corvette ,
philips ,
replacement ,
standard ,
vett ,
xld
