Cam Specs help needed.
Old May 1, 2011 | 02:36 PM
The Mountain Kat's Avatar
The Mountain Kat
Default Cam Specs help needed.
I bought a Vortech SC'ed engine from out of a Z06 with plans for swapping all of the goodies onto my '99. I degree'd the cam so that I could get an idea of what it is. I cannot find anything close on the usual cam-maker's sites so I am thinking that it might be a custom grind. Heck it might even be stock but I doubt it.
Specs are;
Intake: 0.537" on 122CL
246@0.020 lift
219@0.050 lift
Exhaust: 0.529" on 119CL
256@0.020 lift
232@0.050 lift
120.5 LSA
These numbers are etched on the end: 5308 22 s 4096
These are hand stamped in 3 B
Anyone familiar with cams that can give me an idea of what this cam is?
Old May 1, 2011 | 03:22 PM
zeevette's Avatar
zeevette
That sounds like a very good cam for a SC install, but it's very small.
Old May 1, 2011 | 05:49 PM
AU N EGL's Avatar
AU N EGL
219/232 537/529 122+3
small SC cam
Old May 1, 2011 | 08:46 PM
chevylad's Avatar
chevylad
Where did you measure the lift? I might be wrong, but I always thought manufacturers specified lift at the valve with the assumption of a 1.7 ratio rocker.
Old May 2, 2011 | 05:14 PM
The Mountain Kat
I measured the actual valve lift utilizing a 1.7 rocker.
Indicating on the retainer.
It certainly seemed to a smallish camshaft. With my engine I think that I will look for a more appropriate cam.
To Cam Specs help needed.
