hi guys,
I tried to fix my vette but didn't have any luck. Please, this is the link of what I did and if anyone has any idea, I'm open for suggestion. I'm not sure if its something with the computer or the sensors or what.
Thanks,
Tony http://forums.corvetteforum.com/c5-g...ency-help.html
Looks like others have already replied. I had the exact same problem. Would crank and fire during crank but die when starter was released. So I did a lot of searches on this forum. The fuel pump is shutting off when you release the starter. Anyway - The battery was a bit old so I followed the advise from this forum and installed a new battery and cleaned the battery cables real good. And that's it!! Been working perfect ever since and that was about a year ago. I have no idea why that fixes it but it does. Of course you have to clear all codes also.
ok, I will take my new batery from the cadillac sts and we will se... but tomorow, lol . Im tired now and Im watching the
"GREEN HORNET" movie...
Hmmm.....a 98, with a P0601 code. Two forum members called this early in the thread, but for whatever reason, you ignored it. Had you done a search, you would have also found, that a P0601 code is VERY common in 98's, and 99.9% of the time...........is PCM failure.
