Transmission leak?
Old May 4, 2011 | 08:54 PM
69'Silver's Avatar
69'Silver
Default Transmission leak?
A shot in the dark here, but can anyone take a stab at where this leak me=ay be coming from. The picture is from behind on the drivers side. After along drive I will have a small amount of fluid? on the floor. This is an '03 with 24k on the odo. Trip to the dealer I guess..
Old May 4, 2011 | 09:00 PM
ZeeOSix's Avatar
ZeeOSix
Most likely the left axle seal in the differential. There's a TSB on it, and also on the left hand side case possible leakage too.
Old May 4, 2011 | 09:27 PM
bumble-z's Avatar
bumble-z
I agree. Differential out put shaft seal is probably leaking.
You can't see it in your pictures. If you were to take your wheel off, you would have a good view of the leak.
Check your differential fluid level, to be sure your not too low on fluid.
Uses the same seal on drivers/passengers side.
GM part # 088996703 $22.61 ea. @ dealer.
Good luck.
Razor00's Avatar
Razor00
Yup, agree
To Transmission leak?
