Steering wheel puller.. need help
Old May 4, 2011 | 09:10 PM
White Rabbit's Avatar
White Rabbit
Default Steering wheel puller.. need help
Same story as everybody els... i keep breaking the stupid legs off and i want to just buy a quality tool that doesnt snap.
SO anybody know where to buy one.. not my main car so it can be down for a while.
Old May 5, 2011 | 06:26 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Just a little twist, my dealer pulled and replaced mine for $45 You may want to explore that avenue.
Old May 5, 2011 | 01:52 PM
White Rabbit
Car is on jack stands in the garage, half way threw widebody install.. i would rather spend twice that on the tool they used to do yours.. im more of a do it your selfer..
Old May 5, 2011 | 11:36 PM
rpm462's Avatar
rpm462
I broke mine as well but luckily the O'Reilly's auto parts store near my house had the entire kit with the heavy duty ones available to sign out for free.
Old May 6, 2011 | 12:29 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I've removed the wheels on two C-5s, to "modify" the coulum lock plate, and used a KD Tools #3511 puller.
Old May 6, 2011 | 05:23 PM
White Rabbit
Youre a life saver.. and how do you "modify" them. i called chevy when mine started having issues and they told me service records show that my car has had the recall and there is nothing they can do..
Thanks Jon
Old May 6, 2011 | 07:33 PM
leadfoot4's Avatar
leadfoot4
Thanks Jon
If you're successful in removing the steering wheel, as you work your way down the steering column, you'll eventually get to a round "disc looking" thing with 6-8 notches in it. These notches are the "detents" that the lock pin engages, and prevents the steering wheel from turning.
The center of this lock plate has a bit of a hub on one side, and this hub has just enough thickness to it, that it can be chucked up in a lathe, and the outer perimeter of the plate can be cut off. No detents, no lock up....
I did this to my car, as well as one of my friend's cars, about 4-5 years ago.
Old May 12, 2011 | 05:05 PM
White Rabbit
Ok.. so i kinda hate my life right now.. i got the nice puller... GREAT tool.. nothing broke.. but my wheel...
So it ripped the metal strait out, as i read could happen. so my plan B is to JB Weld the holes with the puller legs still installed and tomorrow some time give it another try.. Pics
Ideas if this fails??
Old May 12, 2011 | 10:55 PM
Arnie Chamberlain's Avatar
Arnie Chamberlain
Before I did that I would have drilled/tapped to the next size up or helicoiled the existing holes.
Old May 12, 2011 | 11:19 PM
White Rabbit
...... i didnt think of that... well i guess that will be the next logical step
i kinda feel retarded now but hey... round 2 tomorrow..
To Steering wheel puller.. need help
