FAST 78 or port my LS6 intake?
Looking for some insight. They are the same size 78mm, but would a ported FAST 78 be that much better than a ported LS6 intake?
Are you finding one for cheap? I havent researched this but i figure the amount it would cost you may want to up the size
My question was worded incorrectly. I am debating two options:
1. pay to get my LS6 intake ported
2. purchase a ported FAST 78.
Option 2 is more $$$ and I am wondering if the gains are that substantial to warrant the extra $$$.
A properly ported 78mm FAST will only be approximately 5 hp less than a stock 90mm FAST,this as stated by Mr. Mamo back in the day. I run a ported 78mm FAST and my 383 dynoed at 482/442 rwhp n/a at Livernois Motorsports. If you can pickup the 78mm FAST for a "good price" and then have it ported...it will support more hp than most realize.
I put down 471 rwhp with my self-ported FAST 78. I don't have any way to compare it to a ported LS6 manifold though. If you sell your LS6 manifold for ~$300 and buy the FAST 78, how much money will you be out? You should be able to get the FAST 78 for under $500. I bought mine for $400 already painted, and then I did some port work at home.
If you do end up buying the FAST 78, make sure the sharp edge behind the throttle body is rounded off. Mine had an annoying whistle at throttle tip-in, and Tony Mamo clued me in to rounding off that edge (upper right corner behind the throttle body)
after rounding the edge:
I found a 78mm for $600 and it is not ported. That seems a bit high to me. I am leaning towards porting the LS6 because it seems like more bang for the buck. I don't plan on using any forced induction on my car.
Thanks for all your replies and pics!! Great information.
I agree that $600 is too much for a FAST 78mm intake. You can buy a brand new 92mm or 102mm for $830 and there are always some used 90mm intakes on forums in the $600 range. Of course you would have to buy a larger throttle body if you went with the bigger intakes. From what I understand, the bigger openings will increase throttle response, but I'm not sure if it's worth the money for either your or my cases.
I would wait and go staright to 102 FAST/Ls2 TB.
Former Vendor
1 Post
St. Jude Donor '10-'11-'12
I will say this: the price of the them is stupid !!
You cant find an LS6 for under 300 shipped.. I have a project I am working on and doing a conversion and looked all over for a cheap LS6... none to be found had to go with a Vic Jr
But you also have to look at application... does he have a cam? why does he need more air up top?
I dont about that, I havent used or ported an LS6 BUT there used to be a lot of guys claiming good gains with them.. just as good as a non ported 90...
I plan on putting in a mild cam, LG long tube headers so I might need a little more air up top. The 102 is def way too big for my application, so I am not even considering it. I don't want forced induction or a heavy cam.
I think the decision has been made to go with a ported FAST 78. Thanks all the good info guys.
Just an FYI- I have a BBK CAI and it is no good. I would not recommend it. I did not get it tuned, but my gas mileage actually dropped 2 mpg and I don't feel any difference in the throttle response.
I agree that the FAST 102 is superior in quality to all prior FAST intakes.
Former Vendor
1 Post
I'm not going to banter about it theres no value to it at all.. you believe what you want and we'll call it good
The 102 is best of the best no doubt
It all comes down to application.. cubic inches rpms and need for air
