Exhaust question
Old May 5, 2011 | 08:00 AM
hphammer's Avatar
hphammer
Default Exhaust question
I am trying to put a stock exhaust back on my 98.I purchased manifolds from a 99 and an h pipe from a 00. I cant get it to match up. Which piece is compatible or is neither piece compatible.
Old May 5, 2011 | 09:17 AM
chevy406's Avatar
chevy406
They should be compatible. How far off are the flanges? Try completely removing the support bracket for the h-pipe (connects to the bottom of the bellhousing). That will allow the h-pipe to come forward enough to line up with the manifold flange. Once you tighten up the manifold flanges you should be able to go back and re-install the support bracket.
Old May 5, 2011 | 09:33 AM
lucky131969's Avatar
lucky131969
Elaborate or post pics.
To Exhaust question
