Problem with lights help!
Old May 5, 2011 | 08:55 PM
roelp350's Avatar
roelp350
7th Gear
Default Problem with lights help!
I have a 2000 frc. I turn the swith to turn on my signal lights n fogs n my headlights go up WTF? It didnt do that before.. Whats tha fix? Thanks in advanced
Old May 6, 2011 | 06:33 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Sorry I'm misunderstanding or something. You say you turn on the fog lamps and a turn signal which in-turn causes the headlamps to come up? The fog lamps will not turn on unless you turn on the headlamps. The headlamps will turn on either via the switch or the twighlight sentinel(if equipped). Assuming you are turning them on via the switch, the headlamps will come up if you are selecting the parking lamps only but the headlamps will be out. This will allow the fog lamps to run. Now if you rotate to turn on the headlamps themselves, then back off again, this should lower the headlamp doors but leave the parking lamps on and fogs if you turned them on. Hope I didn't get that backwards for you and if so, someone will jump all over my case about it. I'm injured and can't get out to my car to verify...sorry.
