headlight grinding
Old May 7, 2011 | 08:27 AM
tom macie's Avatar
tom macie
Default headlight grinding
My 01 has a slight problem with the left headlight it opens and closes fine but when it gets to the fully closed position it makes a grinding or buzzing sound I know I am not the first to have this problem any suggestions for a fix?
Old May 7, 2011 | 09:17 AM
japc5's Avatar
japc5
Sounds like your gears are gone!
Here is a good to with link to buy brass gears
http://www.corvetteflorida.com/forum...ad.php?t=13712
Here's another link for buying replacement gears.
http://www.bfranker.badz28.com/
Old May 7, 2011 | 10:27 AM
tom macie's Avatar
tom macie
thanks for the info! i'm headed to the garage to check it out have a great weekend!
Old May 18, 2011 | 04:27 PM
megs87's Avatar
megs87
Default Headlight Problem
The gear is shot inside the motor. Make sure when you order the new one it is brass or aluminum. i prefer the brass that is what I used. it's a little tricky but they come with the directions.. My fix was around 90 bucks for two...
To headlight grinding
