Quick help needed on Exhaust Q........
Old May 7, 2011 | 09:57 PM
Legal Alien's Avatar
Legal Alien
Default Quick help needed on Exhaust Q........
Hi guys,
Trying the search but no joy yet.
Could do with some quick advice as looking at this car tomorrow possibly. C5 Z06 2003 with following mods........
KOOKS LT HEADERS
KOOKS X-PIPE
BB MUFFlerS
COLD AIR INDUCTION
HALTECH AIR BRIDGE
JET CHIP II COMPUTER
Now the chap tells me that it will not pass smog in this setup so I would need to swap something out.
Can I buy a CAT that will replace something inline? I know its a bit of a daft question but I'm really new to the vette scene and have no idea of the standard CAT setup. I'd like to keep as much of the mods as possible but need to register it in my state (NV).
Any clues?
Old May 7, 2011 | 10:10 PM
ZeeOSix's Avatar
ZeeOSix
Don't know about the state of Nevada, but on OBDII cars the "emissions test" consists of a test computer being plugged into the OBDII port under the dash to see if the car's ECU is in a ready state for testing, and if there are any trouble codes set.
Maybe he means it won't pass visible inspection ... if they do a visual inspection in NV.
Old May 7, 2011 | 11:27 PM
Legal Alien
Thanks Zee,
NV is the same with respect to OBD testing. The chap assures me it will not pass the smog in current configuration? However he is in california, which I believe is much more stringent?
Sorry for the noddy questions but as my name suggests I'm from out of country and these rules and regulations are all new to me!
thanks again.
Old May 8, 2011 | 04:07 AM
ZeeOSix's Avatar
ZeeOSix
Originally Posted by Legal Alien
Thanks Zee,
thanks again.
You might call your local emissions testing station and ask them if they do a visual check, or if they just plug in the OBDII tester. If the car isn't throwing any DTCs (diagnostic trouble codes), then I would think it would pass the OBDII emissions testing.
Old May 8, 2011 | 07:36 AM
01_torch_red_vette's Avatar
01_torch_red_vette
You should be able to swap in a catted x-pipe as well. Here in NY they will fail you on the visual for not having cats, but as long as you aren't throwing any codes you can pass if you find someone willing to overlook the cats. I went with a catted x-pipe to avoid the hassle with inspections. If they make you hook up to a sniffer in NV then you definitely want some cats on it.
Old May 8, 2011 | 12:08 PM
Bluefire's Avatar
Bluefire
He won't pass in CA due to the LT headers. If he had shorty headers he would pass.
Old May 8, 2011 | 12:34 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
LT headers are not leagal in some states like Calif--so check to see if you can run them there---also as mentioned cats in some states are just a visual inspection----In calif type states it's much stricter---You CANNOT even change or weld on the cats ( shows signs they have been replaced or altered) legally unless they are 10 years old--has been in an accident or damaged--or has failed a smog test recently-- THEN you are only allowed to use specific brands and models off their accepted list of replacements--
If you can get by with LT's and catless--you must be able to pass the "readiness tests" In Calif we are only now allowed to have one test show "NOT READY" So a re-tune or tune would be needed to disable all the related codes and tests---
ALSO your CAI must also have a CARB. certified sticker displayed under the hood for that CAI --(in calif type states )
Old May 8, 2011 | 03:31 PM
Legal Alien
Blimey fellas this is complicated! The UK is much more straightforward in what is and what isn't allowed.
Thanks for all the replies I think I may be just about getting my head round all this now. So the LT headers run down and under the car replacing the section of exhaust which normally contains the cats? So shortys will then also have either a catted section following OR you will have an x pipe? Is that correct? Anyone got an image of the sections that make up the full exhaust?
It's immaterial for this car now anyway as the Carfax threw up something early in its life that the owner was either not aware of or was keeping to himself!
Having driven a Z yesterday I am now itching to get my hands on one, they are awesome.
Thanks again for the replies.
Old May 8, 2011 | 03:53 PM
imavettegirl's Avatar
imavettegirl
kooks sells a kooks catted x pipe that will bolt right in.
shorties would replace the stock manifolds and bolt to the original catted pipes.
Old May 8, 2011 | 04:38 PM
blackconv's Avatar
blackconv
Keep in mind that the vehicle has to pass the rediness codes programmed into the ECU to pass local emissions. Just because a check engine light is NOT on, doesn't mean that it will pass an emissions test. If the rediness codes show not ready (even with the check engine light off), then you will fail the test.
Bottom line is don't buy a vehicle that doesn't pass your local emissions test, and have the owner you are buying it from run the vehicle through the emisson test station before purchasing. After you buy the vehicle it is up to you to get it to pass. As always, buyer beware.
Old May 8, 2011 | 05:24 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
It really isn't complicated; all of these answers are available from your state's DMV. It best to get the answers from them than from individuals on the internet that do not know about the requirements in your state.
http://www.dmvnv.com/emission.htm
To Quick help needed on Exhaust Q........
