TMPS - Sensor dies at 90mph
Old May 8, 2011 | 02:17 PM
KOZ's Avatar
KOZ
Default TMPS - Sensor dies at 90mph
Weird...
I replaced all four sensors two years ago with new units. They work fine until I hit 90...then the right front sensor dies and I get the service tire mon sys message.
Stop. Sit for a second start rolling the sensor comes back normal. 90mph, sensor dies.....repeat....
Old May 9, 2011 | 05:46 PM
C5at57's Avatar
C5at57
Wow, Canada has 90 MPH speed limits? Makes me want to move north. Ok, enough kidding around. The only thing I can figure is the centrifigal force placed on the sensor at that speed must be pulling a cold solder joint loose enough to break the signal. I would say either replace the sensor or slow down, not much else you can do. Good luck.
