why cant i put gas in
Old May 8, 2011 | 07:02 PM
vet85's Avatar
vet85
Default why cant i put gas in
ok this the 3rd time .....i went on a trip this past week and each time it will only let me put in 2 -3 gallons then it runs out .....and thats after driving around 250 miles this is crazy .then today i stop to put in gas 2 gallons then its in the ground .so this time i didnt leave i just put in 10 cents at a time till finally i got in 7 gallons ....come on guys i need help .this literally took 15 minutes .next month i have a 1500 mile trip planned .....heck just take a guess ill try it ......drop tanks change lines .just what would u do first .....thanks for any good advice .i really dont think im getting 150 mpg .
Old May 8, 2011 | 07:20 PM
jcgunn's Avatar
jcgunn
Search the forum for Jet Pump issues (the non-mechanical venturi pump which transfers fuel from one tank to the other)--your might be T/U
Old May 8, 2011 | 07:56 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You might find the crossover tube has twisted and creased therefore not allowing fuel to get to the right tank. There is another possibility too where back pressure on the nozzle stops the fuel going in. In my case, try turning the fuel nozzle counter-clockwise 90 degrees, so the handle is facing to the rear.
Old May 8, 2011 | 09:33 PM
SaberD's Avatar
SaberD
this is a very common issue. luckily, i have not experienced it.
To why cant i put gas in
