Occasion no start
Old May 9, 2011 | 02:19 PM
lanceg1041's Avatar
lanceg1041
Default Occasion no start
2000 c5 auto 46,000 miles
Having starting problem. I have checked the battery and alternator and both are good.
Turn the key to start and hear one loud click possibly from the passenger footwell and then no crank. Tried changing to a spare key but still the same problem. No flashing security light, no current codes. I'm thinking possibly the ignition switch or the theft deterrent relay. Any suggestions to fix this would be appreciated...Thanks
Old May 9, 2011 | 02:26 PM
lucky131969's Avatar
lucky131969
Use the search function, plenty of troubleshooting, schematics, etc.
Old May 9, 2011 | 02:44 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Is the loud click coming from the solenoid? If so, you've probably got a bad one, assuming your battery is up to full power.
Old May 9, 2011 | 04:24 PM
ICUALL's Avatar
ICUALL
Okay sounds like the starter solenoid is probably the noise you are hearing, if no codes you need to check the wires on the starter. should be tight ! most probably the solenoid has bit the dust. This is a common issue for the C5. Might want to check out http://www.c5help.com/c5_no_start.htm ignore the part about checking codes and look at steps 9 & 10
Old May 9, 2011 | 04:27 PM
lucky131969
....no current codes.
History codes can be just as important for troubleshooting....post them.
Old May 9, 2011 | 04:49 PM
lanceg1041's Avatar
lanceg1041
codes are:
B1000
U1096
U1016
U1064
all History codes.
I do not have a lift or jack stands to check under the car. Trying to repair myself for a possible visit to a dealer (UGH) or some other repair shop...
To Occasion no start
