Averege MPG RESETS
Old May 9, 2011 | 05:19 PM
spiceypuppy's Avatar
spiceypuppy
Default Averege MPG RESETS
When my car is off for at least 8 hours the average mpg resets to 0 can anyone tell me what the problem is. Car is a 2000 convert.
Old May 9, 2011 | 08:08 PM
65GGvert's Avatar
65GGvert
Battery voltage dropping too low when cranking. If you have HUD, you'll notice the page resets to oil pressure also. New battery is in your future, unless the connections are loose or corroded allowing the drop. I think it's 8.5 volts it can't drop below to hold the memories, but I can't say for sure.
Old May 9, 2011 | 10:00 PM
spiceypuppy
Thanks yes the hud does reset to oil. Thanks for the help.
Old May 10, 2011 | 06:31 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree too...battery dropping below the 12.5vdc min. Either battery is done or bad battery connections.
To Averege MPG RESETS
