Anything I should check before reinstalling my dash?
Old May 9, 2011 | 09:31 PM
Sinking's Avatar
Sinking
Default Anything I should check before reinstalling my dash?
I have my dash off to repair my HUD. Is there anything else that is common to fail that requires removing the dash that I should check out while I am in there?
Old May 9, 2011 | 09:40 PM
65GGvert's Avatar
65GGvert
Flasher
Old May 9, 2011 | 09:42 PM
Sinking's Avatar
Sinking
Originally Posted by 65GGvert
Flasher
Definitely going to clean that while I am in here. That has been a real nuisance.
Old May 9, 2011 | 10:57 PM
LoneStarFRC's Avatar
LoneStarFRC
Just watch for the white plastic tab sticking down from the bottom of the IPC module when re-installing it. It's roughly 7/16" wide. It fits into a slot or hole (IIRC) on the support structure. Nothing hard to do really, but it's easy to overlook.
Old May 10, 2011 | 06:30 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The HVAC actuators are a problem with cracked gears but unless you are having issues or codes with them, nothing you can do at this time.
To Anything I should check before reinstalling my dash?
