Need relay/Diode wiring help
Old May 9, 2011 | 10:33 PM
wascapsfan's Avatar
wascapsfan
Default Need relay/Diode wiring help
xxx
Old May 11, 2011 | 05:24 PM
C5at57's Avatar
C5at57
Your relay has a normally open and a normally closed set of contacts, run your red cove LEDs through the normally closed set of contacts to your running lights circuit. Then connect the relay coil to your blinker relay coil. That way, when the blinker is OFF, power will flow through the normally closed set of contacts to the red cove lights and when then blinker is turned ON the other relay will energize and turn the red cove lights off. I am assuming you know something about electronic theory. Drop me a PM and I can give you my phone number if you have any other questions.
