disscusting seat
Old May 10, 2011 | 02:47 AM
Mikejan's Avatar
Mikejan
Default disscusting seat
hi Guys ,my c5 seat problem.as soon as I touch the seat switch to pull forward . the car loose all power and looks like dead battery totally & after 0ne hour or dissconectiong battery cable .the electrical system comes back I also can hear fast kind of click noise under cluster. so can you Guys help me.I have this car for 3 months and couldnt drive once. to many electrical headache.thanks People.
Old May 10, 2011 | 09:22 AM
dougbfresh's Avatar
dougbfresh
Sounds like a problem with the seat module under the seat.
Old May 10, 2011 | 01:18 PM
DeeGee's Avatar
DeeGee
Check the connections in the door hinge area. Its common for wires inside the rubber gaiter to make contact with the metal frame and damage the insulation. If you're getting a short in there it will cause the problems you're seeing.
To disscusting seat
