A/C more stuff!!!!!
Old May 11, 2011 | 07:41 AM
Irish Whiskey's Avatar
Irish Whiskey
Default A/C more stuff!!!!!
Tore the right fender off and got the vacuum lines working and there is plenty now and air blows strong and the "mode" control works - cold air only on passenger side not on center or left vent -
I know this signals "actuator" stuff - BUT there are not now no have there ever been any HVAC codes - any thoughts??
Old May 11, 2011 | 07:52 AM
lucky131969's Avatar
lucky131969
The actuators are driven electrically, with a feedback circuit. When they are out of position, it generates a code.
Old May 11, 2011 | 07:57 AM
dmarkshark's Avatar
dmarkshark
Doesn't really sound like actuator problems. Sounds more like a low freon as that will cause this issue. I assume it is blowing warm on the drivers side? I know my car did that, plus it threw the actuator code (even though that was not the problem). I would say check the freon with gauges.
Old May 11, 2011 | 10:24 AM
rebelheart's Avatar
rebelheart
Low freon level would be my first guess also!
Old May 11, 2011 | 07:47 PM
bighank's Avatar
bighank
Default Don't have to rip the fender apart to get to the check valve
I replaced my check valve (actually twice) by simply taking 2 or 3 screws out of the shroud under the fender and then slightly prying it over enough to get my huge hand inside. If I can do it anyone with smaller hands should be able to also.BIGHANK
To A/C more stuff!!!!!
