Harmonic Balancer Wobble
Old May 11, 2011 | 12:01 PM
c599vette's Avatar
c599vette
Default Harmonic Balancer Wobble
I have a 1999 vette that I bought about a month ago and noticed that the balancer has a noticable wobble. It has been this way since I bought it. It did have a squeal but that has since gone. The origional owner had the balancer change prior to my purchase becuase of the noise. The noise came back shortly after replacement so I started looking into this issue and have seen all kinds of comments from pully delaminating to moving front to back etc. I took the belt off and was expecting to be able to move it back and fourth. To my suprise, no movement. The pully seems solid. Does any know if the pully's came from the factory with a wobble.
Old May 11, 2011 | 12:40 PM
The Wrench's Avatar
The Wrench
Yes, quite a few wobble from birth. The dealer won't change one out under warranty even if it wobbles more than 1/8 inch.
And, yes, OEM balancers do fail quite often on the Vettes. The two major fail modes are the bolt backing out, and the rubber delaminating and slipping.
DG
Old May 11, 2011 | 01:04 PM
c599vette's Avatar
c599vette
Thanks. Looks like I'll be changing it.
Old May 11, 2011 | 02:20 PM
Old Horsepower's Avatar
Old Horsepower
I've read a lot of posts on this. Crazy how some wobble. How can that help balance engine and be wobbling? I have a 99 also and its rock solid steady. And I have read posts here where they change out the balancer with a new one it still wobbles!
Old May 11, 2011 | 02:27 PM
Paul 75 L82's Avatar
Paul 75 L82
If your going to change out the balancer you might as well install a small cam. Removing the balancer is half of the cam job. Anyway food for thought.
Old May 11, 2011 | 05:22 PM
mre1974's Avatar
mre1974
Exactly what I have planned for mine...just need to find the time for the guy to do the work for me.
Old May 11, 2011 | 09:46 PM
guido7834's Avatar
guido7834
Excuse my ignorance, but what is a cam? I am not a mechanic type, but hear so much about cam this and cam that.
Old May 11, 2011 | 10:30 PM
bracketshark's Avatar
bracketshark
This link will show You a camshaft and explain its purpose:
http://en.wikipedia.org/wiki/Camshaft
Old May 12, 2011 | 07:07 AM
guido7834's Avatar
guido7834
OK, so what is the reason/benefit of changing one?
Thanks!
To Harmonic Balancer Wobble
