Valve Guide Seals for LS6
Old May 11, 2011 | 07:48 PM
ZeeOSix's Avatar
ZeeOSix
Default Valve Guide Seals for LS6
Does anyone make an aftermarket valve guide seal that is supposed to be better than the GM part? If so, who makes them?
I was told by the GM parts dept that the intake valve guide seals are different than the valve guide exhaust seals. Not sure why.
Old May 11, 2011 | 08:05 PM
wfdlt8's Avatar
wfdlt8
They are different I just installed some and it is a fairly simple job.
Old May 11, 2011 | 09:05 PM
vettenuts's Avatar
vettenuts
I have actually found the GM seals to be very good, not sure why you don't want to use them. Intakes are black, exhaust brown. Intakes are slightly more pliable and the exhausts need to take the heat. The one piece seal/seat on the 02+ motors are a slick piece that are held firmly in place by the valve spring. If you have ever had the seals come off the guides and ride up and down with the valves you know what I mean.
Old May 11, 2011 | 09:07 PM
81c3's Avatar
81c3
Anyone doing valve springs should replace the seals as well...its that easy....
Old May 12, 2011 | 12:27 PM
ZeeOSix's Avatar
ZeeOSix
Didn't say I didn't want to use them ... just wondering if there are aftermarket seals that are any better.
The OEM GM seals aren't real cheap either ... quote was ~$60 for a complete set. Can OEM GM seals be found at a better price from some of our site vendors?
Maybe that's why they are a little pricey ... this is for a 2002 Z06.
Old May 12, 2011 | 01:13 PM
Paul 75 L82's Avatar
Paul 75 L82
I just checked at Jegs and the Comp Viton seals are $16.00.
Old May 12, 2011 | 02:36 PM
vettenuts's Avatar
vettenuts
Note that an umbrella seal will require valve spring seats if you don't use the GM seals, so you need to factor that into the cost as well.
Old May 13, 2011 | 01:08 AM
ZeeOSix's Avatar
ZeeOSix
I've never seen the setup on the OEM valve guide seals, so I'm kind of lost on the difference between them and umbrella seals. Here's some of the aftermarket valve guide seal for the LS6.
http://www.autozone.com/autozone/par.../N-jh4w9Z93xkd
Are the Comp Cams guide seals similar to the GM OEM seals? I'll probably just go with the GM seals. My Z06 only has 21K miles, but it is 10 years old now, so I definitely want to change them while I'm doing the valve spring swap (using PAC 1518 springs).
Old May 13, 2011 | 05:22 AM
vettenuts's Avatar
vettenuts
I have some photos at home, will try to remember to post them. The 02 seal sort of looks like a metal top hat.
Old May 13, 2011 | 03:10 PM
ZeeOSix's Avatar
ZeeOSix
That would be helpful if you can post some photos.
So correct me if I'm wrong, but from what I'm understanding is that the OEM valve guide seals have some kind of meal seat for the bottom of the spring to sit on?
Do these look similar to OEM seals? Click "Enlarge Image" once you open the link below.
http://www.autozone.com/autozone/par...9_207982_6534_
Also, I'm hoping that the PAC 1218 or 1518 springs will work with the stock valve guide seals?
Old May 13, 2011 | 03:14 PM
vettenuts's Avatar
vettenuts
This is the seal that was on my Dart heads, same manufacturer and design as the GM seals. Note that the bottom is the valve spring seat. Any shimming for height goes on top of the seat, not under it.
Old May 13, 2011 | 10:47 PM
ZeeOSix's Avatar
ZeeOSix
vettenuts - thanks for the photo. I see exactly what you're talking about now.
These Victor Reinz brand guide seal look similar ... not sure if they are a good brand or not. They show a different p/n for intake and exhaust like GM does. I'll just see if I can find some GM seals at a good price.
Old Jun 8, 2011 | 07:42 PM
ducatisl's Avatar
ducatisl
5th Gear
ZeeO6,
Did you finish your beehive spring install?
Seems to me the GM combo seal/seat has too much clearance to the I.D. of the 918/1518 beehive spring...if that's even a problem as it seems everyone just swaps the springs in, keeping the stock retainers/seals/seats.
Old Jun 8, 2011 | 08:23 PM
NatB's Avatar
NatB
Why? With stock valvetrain - other than maybe the springs, why ?
Go with the parts made for your engine.
Old Jun 8, 2011 | 08:35 PM
ducatisl's Avatar
ducatisl
5th Gear
spring ID = 0.885
0.800 for OEM locator OD step on combo seal/seat
Doesn't that seem like a bit much?
Old Oct 11, 2011 | 12:59 PM
SuzukiDan7's Avatar
SuzukiDan7
I'd like to bump this, hoping for some more info - I'm going to do the pac 1218 beehive springs in my 02 z06 this winter, and want to make sure I get the correct valve seals. Can anyone point me in a 'confirmed' right direction? Should I just get OEM ones from a dealer?
Old Oct 11, 2011 | 01:08 PM
ducatisl's Avatar
ducatisl
5th Gear
I went with the Manley 42336-16 spring seat and a Comp 511-16 seal.
To Valve Guide Seals for LS6
Old Oct 11, 2011 | 03:22 PM
SuzukiDan7's Avatar
SuzukiDan7
How about these guys from Rockauto? OEM for .. ls1, ls6? I'm not sure if these will work:
VICTOR REINZ Part # B45921 {#12482063} intake
http://www.rockauto.com/catalog/moreinfo.php?pk=2651560
FEL-PRO Part # SS71039
http://www.rockauto.com/catalog/moreinfo.php?pk=447259
DNJ ENGINE COMPONENTS Part # VSS3166
http://www.rockauto.com/catalog/moreinfo.php?pk=1827364
Old Oct 11, 2011 | 03:33 PM
ducatisl's Avatar
ducatisl
5th Gear
There's a bit of play when using the beehive and a OEM seal/seat, but people install this combination all the time. You might check your installed spring height as the OEM piece is thinner, on the order of 0.030'ish versus 0.060 for the Manley or Ferrea (SL1080) seat.
Old Oct 11, 2011 | 03:39 PM
lucky131969's Avatar
lucky131969
I bet these guys can for sure:
PAC Racing Springs
21200 Telegraph Road
Southfield, MI 48033 USA
www.RacingSprings.com
Toll Free: (866) 799-9417
