Window Motor Diagnosis
Old May 11, 2011 | 11:01 PM
foggy's Avatar
foggy
Default Window Motor Diagnosis
2000 Vert
After its long winter nap, The Passenger
side window will no longer go down. I can hear
the relay or whatever it is at the door. It won't go down
with either door switch or with convertible top button.
Stuck UP!
So, before I tear into the door, just want to confirm
that it is the motor.
Thanks for any help
Old May 11, 2011 | 11:06 PM
RossJackM's Avatar
RossJackM
I have an intermittant problem with my passenger side window, but it goes away if I shut off the ignition and restart. Check the battery voltage... Marginal voltage can plague the system computers.
Old May 11, 2011 | 11:30 PM
65GGvert's Avatar
65GGvert
Turn on the key, hold down the window down switch and give the door pull a good thump with your fist, or slam the door while holding the switch down. Once it breaks loose, run the window up and down a few times and it will probably work until you store it again. The contacts in the motor get stuck.
Old May 11, 2011 | 11:51 PM
foggy's Avatar
foggy
OK, will try that.. Figured it was in a "bad" place on the'
motor. Thanks for the help
Old May 12, 2011 | 06:25 AM
Marlin's Avatar
Marlin
Mine also started to work and not work on the pass side.
I just replaced the full motor/track in the door. There is a thread here about that. Someone found someone on eBay selling the complete peice at a fair price. So I bought one of those and just replaced mine.
Been working great since then.
To Window Motor Diagnosis
