And is there any such thing as Horsepower in a bottle?
Thanks guys!
Nitrous :p:
Higher octane fuel won't do much, if anything, for you unless you're running higher compression, or are otherwise heavily modified.
It's not worth the money otherwise :cheers:
READ THIS!! http://forums.corvetteforum.com/zerothread?id=282975
Yep, pretty much a waste of money. If my car were stock and a daily driver, I'd be very tempted to run 89 octane unless I knew I was going to do some spirited driving. Gas prices are way too high these days.
what about with my setup ? it is a semi daily driver, the compression is not high NA as it was built that way for n20 use of which I use about a bottle a week. recently I have been using 3 gallons of c16 racing gas, it seems to run stronger (placebo ?) but it is getting expensive @ >$7 a gallon, any thoughts.
