4th Gear grind
Old May 14, 2011 | 08:41 AM
Sinister-Z's Avatar
Sinister-Z
Default 4th Gear grind
So after two passes at the track last night (1/4 mile) the tranny is now grinding when going into 4th gear. It only does this on higher RPM shifts. It seems to shift into 4th fine when your not on the throttle.
I have done some research and it seems that the syncros might be bad. I have also seen other posts about the shifter not being properly aligned. It currently has a B&M Ripper and seemed to be fine prior to last night. The clutch is an Texralia OZ 700 (4k miles) and seems fine also
The tranny fluid (Amsoil) has just been recently changed so I don't believe that is an issue either.
Any thoughts?
Old May 14, 2011 | 09:39 AM
helga203's Avatar
helga203
Any thoughts?
Do you have trick M/C or stock ?
Old May 14, 2011 | 11:09 AM
Sinister-Z's Avatar
Sinister-Z
As far as I know it's stock.
Old May 14, 2011 | 06:07 PM
Sinister-Z's Avatar
Sinister-Z
Hmmm....guess it's time to pull the tranny.
Old May 14, 2011 | 09:34 PM
n8dogg's Avatar
n8dogg
its common actually, you can pull the tranny all day and have the same prob with new oem parts. try another fluid.
Old May 14, 2011 | 10:24 PM
Sinister-Z's Avatar
Sinister-Z
I'm using Amsoil torque drive fluid which seems to be one of the most recommend fluids on the forum. I think it might be more serious than that.
Old May 15, 2011 | 01:58 AM
rustyguns's Avatar
rustyguns
mine does this when fluid is old. sometimes too slippery a fluid does not let your syncros work
i heard the new gm stuff is really good and i think it is the same as valvoline. i am going to try it next, my 4th gear is starting to grind a bit again
do a search
Old May 15, 2011 | 10:16 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Highly doubt it is the fluid, this is probably the most shear stable tranny fluid on the market. I've been using this fluid for years in mine at I shift much more often than at a 1/4 run and have not had any problems.
The Tremec T-56 has many well know problems in this area including both the synchros themselves and the shift forks which can bend, particularly when used hard which may be the case more in 1/4 mile runs than at a road course. A common fix is to go to steel vice aluminum shift forks.
Do a search for bent shift forks.
Another common problem is the clutch slave cylinder which lets air get into the system resulting in poor clutch disengagement. Bleeding the clutch often can help mitigate this, but ultimately, changing the slave cylinder will be required. Note that bleeding the clutch is a major PITA. But, I've done it enough that I now can reach up in front of the tunnel heat shield plate, around the exhaust manifold and get a wrench on the bleed port without having to remove anything. Need small hands...
Good luck!
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old May 15, 2011 | 02:11 PM
ragtopws6's Avatar
ragtopws6
If you are having problems shift ONLY into 4th gear at high RPM, then it's NOT the fluid, shifter or clutch hydraulics. If you have shifting problems in all gears, then that would be different. If you are pulling the trans, inspect the 3-4 shift fork pads and 4th gear blocking rings very closely.
I had one with the same symptom a while back and it was a cracked 4th gear blocking ring.
Contrary to popular belief, the shift forks do not bend. The 5-6 and reverse forks are made of steel and 1-2/3-4 forks are made of aluminum (later model C5 units had steel 3-4 fork). I have seen them break but never bent.
Old May 15, 2011 | 03:34 PM
TXGS507's Avatar
TXGS507
syncro's... been there, done that. It will only spread and get worse.. kinda like cancer!
Old May 15, 2011 | 10:02 PM
Sinister-Z's Avatar
Sinister-Z
It looks as if I will be pulling the tranny but I have never attempted to dig into the internals of a M6. I have played with valvebody kits with a A4's and such but woould rather let a pro crack it open.
The car was suppose to have a "Level IV" tranny with only 3k miles since the rebuild. It was done by A One Transmission Performance in Pasadena Maryland by the previous owner. He gave me the invoice that showed that he paid $2300 to have it done.
The invoice is hand written and a little hard to read. But I can make out that is got (4) new sycros and 3-4 steel shift forks. Also something about a 3rd case speed gear.
The car is pushing a lot more power (600+) thanks to the A&A sc and meth. I was hoping it would last longer but no use dwelling on it. I am looking into a RPM level IV or V tranny although I'm not entirley sure yet,
Old Mar 15, 2016 | 05:57 AM
David Tatlonghari's Avatar
David Tatlonghari
4th Gear
i have a 2001 base corvette. 5th gear wont go through it just grinds so bad. 1st to 4th gear works just fine. any help would be appreaciated.
To 4th Gear grind
