car broke last night code help
Old May 15, 2011 | 02:05 PM
jv01's Avatar
jv01
Default car broke last night code help
service light came on last nite do these code mean anything to anybody. car still runs . the only thing that i see is , voltage seems low 12s nothing over 13.1 if that's any help jim v
borfa c2120 h c
bo521 h
u1160 h
po751 h c
p1626 h
Old May 16, 2011 | 08:37 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
C2120 TPM System Malfunction (No Sensors Received)
U1160 Loss of Communications with LDCM
P1626 Theft Deterrent System Fuel Enable Circuit
The P0521 code isn't in the normal list but shows problems with your oil pressure sender. What is the oil pressure reading? Similarly not seeing the P0751 code but it shows issues for a shift solenoid, generally speaking.
Low voltage will cause all sorts of issues as you need a minimum of 12.5 static with the ignition off, for the computers to run. So you might want to check into that area first, clear the codes, then check them again...after fixing the voltage issues...bad battery connections, battery age, starter solenoid battery connections...
Old May 16, 2011 | 06:10 PM
jv01's Avatar
jv01
thanks i started the car after work to day and it was reading 14 volts. thanks for the tips jv
my oil pressurer is between 40+ AND 70+ I have a lingenfelter car so some of the readings are diff from stock
To car broke last night code help
