LS6 harmonic balancer part number??
Old May 16, 2011 | 10:09 PM
pfcvo's Avatar
pfcvo
Default LS6 harmonic balancer part number??
Hi all,
I tried searching all over CF but could not find this part number. Is the LS6 harmonic balancer the same as the LS1/LS2's? Part Number: 12553118 ?
Thanks in advance
Old May 17, 2011 | 12:10 PM
corvettebob1's Avatar
corvettebob1
The LS6 is exactly the same balancer as the LS1, but wait why do you want to install an inferior part?
Go aftermarket for this item I would never install a stock balancer on an LS engine with the failure rate seen here.
Old May 18, 2011 | 07:05 AM
pfcvo's Avatar
pfcvo
Thanks! I had thought about the ATI harmonic balancers but I just can't justify the $400 dollar price tag. The stock one I had lasted about95,000 miles before it came off, and I don't baby my Z06 either (VIR Full Course, autocross, 1/4 mile). Hopefully red locktite on a new bolt will help the replacement HB stay in place.
Old May 18, 2011 | 07:51 AM
VET IT B's Avatar
VET IT B
Usually it's not the bolt. They come apart at the rubber seals.
Look into Powerbond, they can be had for under 100.00.
Old May 18, 2011 | 01:08 PM
zeevette's Avatar
zeevette
Lots of stock balancers don't last 95k miles, even babied. Don't do it! BTW, cam it.
Old May 18, 2011 | 05:54 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
This C5 ownership deal is getting very annoying. The headlight gears strip, the seats rock, the rocker arms spit their needle bearings, the valve springs are failing, and now the harmonic balancers are suspect.....
Old May 19, 2011 | 08:20 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
I would certainly be happy to help you out with new GM. Feel free to send me an email, give me a call or visit our website.
Old May 19, 2011 | 11:19 PM
4SFED Z's Avatar
4SFED Z
Nothing wrong with stock harmonic balancers. Dealership here in tx 103 out the door. Ebay, 85 plus ship
Old May 19, 2011 | 11:20 PM
4SFED Z's Avatar
4SFED Z
Btw factory doesn't locktite them
Old May 20, 2011 | 11:04 AM
lionelhutz's Avatar
lionelhutz
Do not red locktite the bolt.
Just how are you going to heat the threads of that bolt to break the bond of the red locktite when you can't get a torch on the area that needs to be heated? Other people who have done that or had that done ended up with a broken bolt when they tried to remove it again.
Only install a new GM bolt as per the manual unless you want to screw it up for the next time it has to come off.
Peter
Old May 20, 2011 | 01:10 PM
Paul 75 L82's Avatar
Paul 75 L82
I used 12560115.
To LS6 harmonic balancer part number??
