Help with Hypertuner
Old May 18, 2011 | 11:16 AM
megs87's Avatar
megs87
Default Help with Hypertuner
I purchased a hypertuner III I believe when I purchased my c5 approximately sebven years ago. Still to today I haven't even tried it. Any suggestions or tips out there... I just don't want to do any damage...
Thank you
Anthony
Old May 18, 2011 | 04:15 PM
jcgunn's Avatar
jcgunn
It's a no brainer--just follow the prompts. If you did not change the T-Stat, then skip that part.
Old May 19, 2011 | 11:26 AM
megs87's Avatar
megs87
Default Hypertuner
Thank You I will try that and get back to you...Probably in a couple weeks just had an operation...
Old May 19, 2011 | 11:37 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Make SURE your battery is FULLY charged before you begin.
If the battery voltage gets too low, while the programmer writing to the PCM, all memory will be lost.
To Help with Hypertuner
