CAGS...a little feedback
Old Apr 21, 2002 | 01:16 PM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
Default CAGS...a little feedback
I have done this on a C4 but not on C5 I am sure it is just as simple but anything I should look for and what should I expect?
Old Apr 21, 2002 | 01:25 PM
borba's Avatar
borba
Default Re: CAGS...a little feedback (iceburgh68)
Buy the CAGS bypass or do a thread search and install a resistor yourself in place of the bypass. The Bypass kit is cheap and works great. Just My 02's :yesnod:
Old Apr 21, 2002 | 01:56 PM
pridnjoy's Avatar
pridnjoy
Cruise-In III Veteran
Default Re: CAGS...a little feedback (borba)
Yeah, go with the CAGS defeat. Only $20 and 2 minutes and you are banging through all the gears...as you wish!
Old Apr 21, 2002 | 02:21 PM
AFVETTE's Avatar
AFVETTE
Test drove a friends car after he upgraded his suspension but forgot he doesn't have the CAGS eliminator, I found myself lugging the engine in 4th when I wanted 2nd. I wasn't about to man-handle his car to cause the car to by-pass the CAGS but still wanted to pull 2nd in town. Spend the few bucks and get rid of this major PITA. You paid for 6 gears?
Tom
Old Apr 21, 2002 | 02:46 PM
DsC5's Avatar
DsC5
Nothing special to look for - simple addition. Well worth the $20 IMO.
Old Apr 21, 2002 | 02:53 PM
HEB's Avatar
HEB
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In IV Veteran
Default Re: CAGS...a little feedback (DsC5)
Ditto for me just installed the CAGS defeat yesterday on my 2002 that I picked up Fri. Follow the instructions that come with the part,back your car up on ramps or use a lift if avaliable.
HEB
2002 torch red coupe MN6 :D
Old Apr 21, 2002 | 03:30 PM
Michaeljh3's Avatar
Michaeljh3
If you would rather save the $20, just go to radio shack and buy a 2.2k end of line resistor.
Old Apr 21, 2002 | 04:02 PM
gmblack3's Avatar
gmblack3
Default Re: CAGS...a little feedback (Michaeljh3)
Here are some pics:
http://www.picturetrail.com/gmblack3/647207
http://www.ls1.com/link_cags.html
Old Apr 21, 2002 | 04:34 PM
canuckz's Avatar
canuckz
Default Re: CAGS...a little feedback (gmblack3)
The cags defeat is the best $20 you will spend.
Old Apr 21, 2002 | 11:42 PM
Mark VerMurlen's Avatar
Mark VerMurlen
The CAGS defeat is almost identical between the C4 and C5. I put the CAGS defeat in both my previously owned C4 and my new C5 and other than the location of the plug, its entirely the same. It's a little weird to find the transmission in the rear of the car on the C5 when you're accostomed to seeing it right behind the engine on the C4, but you'll get used to that.
- Mark
Old Apr 21, 2002 | 11:50 PM
TooManyIDs's Avatar
TooManyIDs
Just remember that it's in the back. :D
To CAGS...a little feedback
