Fog light shroud assembly question
Old May 20, 2011 | 10:37 AM
kennya35's Avatar
kennya35
Default Fog light shroud assembly question
Finally got around to messing with the fog light shrouds yesterday and the passenger side is "droopy". It has two screws in the bottom of it, but nothing holding the top of it in place. The drivers side is correct, although i didn't see any screws, so it must attach somehow. Does anyone have a picture of how it stays in place? Just hope I explained it well... Thx all.
Old May 20, 2011 | 11:32 AM
C5sleeper's Avatar
C5sleeper
no picture here but there should be 2 tabs that retain it towardsd the inside of the car and one that also attaches to the running lights that is vertical i belive, If you pull off your access pannels on the bottom between the inner fender and the bumper you can access them easily with a swivel.
Old May 20, 2011 | 12:20 PM
kennya35's Avatar
kennya35
Thanks sleeper. I was thinking it should be tabs. Waiting for the rain to quit and I will check it out. Who ever had the car before me put some kind of bracket in the outer part of the bumper and used screws, so I think once I get those brackets out, I am going to have two small screw holes in that area on both sides... I think those brackets were maybe used for screens. I am pretty sure they shouldnt have screwed through the bumper. Idiots...
To Fog light shroud assembly question
