Intake Torque Specs
Old May 20, 2011 | 03:47 PM
lavery48's Avatar
lavery48
Default Intake Torque Specs
What are the torgue specs on intake bolts on a c 5 ?
Old May 20, 2011 | 04:09 PM
The Wrench's Avatar
The Wrench
Not much: 44 lb inch on the 1st pass, then 96 on the 2nd pass.
That's equivalent to only 8 lb feet.
You should also tighten in a kinda circular pattern, starting at the 3rd right bolt. The pattern is as follows for the 10 bolts:
3R, 3L, 4L, 2R, 4R, 2L, 1L, 5R, 5L, 1R.
DG
Old May 20, 2011 | 04:19 PM
lavery48's Avatar
lavery48
Thanks so much DG !
Old May 20, 2011 | 04:54 PM
Darion's Avatar
Darion
PM for ya.
Darion
Old May 20, 2011 | 04:59 PM
hotwheels57's Avatar
hotwheels57
http://www.eliteengineeringusa.com/C5_Torque_Values.pdf
To Intake Torque Specs
