rocker arm issue
Old May 21, 2011 | 10:41 AM
Blow Torch's Avatar
Blow Torch
Default rocker arm issue
Oh well...I stared the head swap on my wife's cam car and found the dreaded "needle bearings in the heads" from a crashed GM rocker arm
Question; has GM fixed this issue, or is that always going to be an issue with stock GM rocker arms with cams in the 600 (598/601) range?
I hate to spend $500 bucks on Yella Tellas for a car that will NEVER see a drag strip and not be abused.
Also looking at the LS7 rockers at around $19 each
Any thoughts?
Old May 21, 2011 | 11:04 AM
vettenuts's Avatar
vettenuts
LS7 rockers won't work. You can either look for a used set and upgrade with the trunnion bearings or per "Eric D" who works for GM, the new rockers no longer have this issue so a new set from a GM vendor may be your fix.
Are you running on GM heads?
Old May 21, 2011 | 11:26 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
We can rebuild your rockers for $199 with the Comp cam trunnion kit. It will take care of the needle bearing issue. We have rebuilt sets in stock ready to go
Old May 21, 2011 | 11:46 AM
Blow Torch's Avatar
Blow Torch
Thanks VN
They are AFR 205s
Its interesting that Summit advertises the LS7 "exhaust as a bolt on for LS1 etc
I hadn't thought much about them until I saw them on Summit
99BC
Pming you
Old May 21, 2011 | 03:36 PM
vettenuts's Avatar
vettenuts
You sure you want to run stock rockers with the bronze guides? Might be better off with the YT's. I couldn't get a good wipe out of the stock rockers but got an excellent one from the YT's.
Old May 21, 2011 | 06:50 PM
Blow Torch's Avatar
Blow Torch
Hadn't really thought about it until now, since I wasn't aware of the problem beforehand
I just hate to pay $500 for a set of rockers for a weekend cruiser that rarely gets beat on. (she just uses it to embaress the camaro and mustang kids )
Old May 21, 2011 | 08:31 PM
vettenuts's Avatar
vettenuts
Wow, they went up since I bought mine
Old May 21, 2011 | 10:04 PM
Blow Torch's Avatar
Blow Torch
yep, mine too
$479.00
Old May 21, 2011 | 11:04 PM
81c3's Avatar
81c3
^this^
To rocker arm issue
