estimated horsepower with these mods
Old May 21, 2011 | 01:31 PM
aslp19's Avatar
aslp19
Default estimated horsepower with these mods
Im changing the cam from a very very mild one to the G5X3 and was wondering roughly what it should put down . Its a FRC car here is a list of mods.
Mods:
-AFR Aluminum 205cc Mongoose Heads
-LG G5x3
-Comp Cam Magnum 5/16” Hardened Pushrods 7.400”
-Comp Cam Replacement Roller Lifters
-ATI Super Damper Aluminum 10% under w/ AC
-Ported FAST 92mm Intake Manifold
-LS2 90mm TB-Z06 85m MAF
-Callaway Honker Cold Air Intake w/ K&N Filter
-42LB Lucas Fuel Injectors
-Katech C5 Ported LS1 Oil Pump
-Katech HD Timing Chain
-Katech Solid Tensioner for C5/Z06
-LG Motorsports Pro 1 ¾ Headers with 3” X-pipe
-Borla Stinger Exhaust Duel Outlet
Old May 21, 2011 | 05:38 PM
zeevette's Avatar
zeevette
What were your previous cam specs? Are the AFR heads milled?
Old May 21, 2011 | 06:58 PM
aslp19's Avatar
aslp19
-Comp Cam 220-224 not sure if the heads are milled
Old May 22, 2011 | 03:08 AM
zeevette's Avatar
zeevette
Stock chamber size for AFRs is 66cc, I think, so your compression should be around 10.5:1. If you live where they sell 93 oct. there's some power left on the table. The cam difference will probably be around 15-20+ RWHP, but your power peak will be higher, and narrower. The X3 is used alot, but I think it's better for drag racing than street or road racing.
Old May 22, 2011 | 10:56 AM
CTD's Avatar
CTD
How are your tuning skills?
Previous dyno #'s?
Old May 22, 2011 | 11:24 AM
aslp19's Avatar
aslp19
449 ( dyno dynamics )whp but I think the number was a bit inflated by last owners build shop. I havent had it dynoed myself.
Old May 22, 2011 | 11:28 AM
aslp19's Avatar
aslp19
I have zero tuning skills but have a great tuner here in KY
Old May 22, 2011 | 11:37 AM
CTD's Avatar
CTD
I will go with zeevette on all of his comments.
With a slightly bigger cam (not the X3) that would still retain drive-ability & additional head work, milling & some porting work. Depends on your definition of street ability.
My previous 346 with 228/228 was touching 500 rwhp with very nice street manners, my current 416 with 243/247 is not nice.
Who is your tuner?
Old May 22, 2011 | 11:44 AM
aslp19's Avatar
aslp19
the tuners here are short tuning and blue cat. Im not much on the track its like 1 1/2 hours away from me so I need something to get down on the street with. Any ideas ?
Old May 22, 2011 | 12:43 PM
CTD's Avatar
CTD
How bout something like this, I'm assuming 6spd.
4:10's with tires that will hold, trans brace (so you don't bust it), a real clutch, not LS7, something like RPS twin. Sends your heads to Tony. A bit more camshaft, make sure the rest of the valve train is up to task. Then you will have a freely reeving 7K rpm motor that hits hard with manners!
Oh & a 3" cat-back.
Old May 22, 2011 | 12:58 PM
aslp19's Avatar
aslp19
Oh & a 3" cat-back.
It is DTE braced and has a twin disc from kentucky clutch. What size cam should I go with ?
Old May 22, 2011 | 01:30 PM
CTD's Avatar
CTD
If you were to have Tony re work the heads I would discuss the cam with him. Mine was 228/228 that was touching the 500 rwhp.
There is thread over on LS1 tech were someone went a bit more cam than I did....I will try & find it.
Old May 22, 2011 | 01:42 PM
CTD's Avatar
CTD
Here you go.
http://www.ls1tech.com/forums/dynamo...5-results.html
Old May 22, 2011 | 02:41 PM
zeevette's Avatar
zeevette
If you have AFR heads, theres nobody better than Tony Mamo. Also get cam advice from him. He used to post quite often, but I haven't seen one for a while. He sells/works for AFR, and although he's prone to advise AFR, properly done, they're capable of great results. And they're far better made than factory heads.
To estimated horsepower with these mods
