The passenger door electricals do not function in my 03. I know it is a bad connection in the 6 wire connector located in the boot that goes between the drivers door and the car. I think I can fix it if I knew which wires in the connector make the passenger door function
Bill Curlee or Lucky131969 will have the schematic. You should be able to open the door accordian tube and look at the connector. Check your fuses. Pull your codes and post them.
Jnape, thanks for the link, but I went through every one of them and couldnt find any of the connections that refrenced the power windows, mirror or door locks. any ideas ?
First of all, thanks for taking the time to get me the info, but I think the diagrams only go to c4. I did replace the block in the drivers door and that half works, would you have the drawing for the c5 ?
Thanks Dino
This is a C5 document. Look at the top of page 1. 2003 corvette.
Do you have a C4.
Yes mine is a 2003 C5, just kind of curious as to why their connectors in the diagram dont look like mine. The vehicle is totally stock. I guess I will just have to use a meter and trace them all back. Lot of work but have no choice
