Ecl code 1635 wtf
Old May 22, 2011 | 10:54 AM
99mikeb's Avatar
99mikeb
Default Ecl code 1635 wtf
Code @ PCM 1635 is (5 volt reference #1 circuit) what does that mean
tested with volt meter at the battery and get 13.2 do i have a bad relay????
At the dic volt reading jumps 13.2 to 12.1 back and forth when idling
is the battery on it's way out ,should i have the battery load tested,
the car been sitting for 2 weeks and had to charged the battery over night.i always use me battery tender but diden't realize i had it set for 6 volt.
The engine check light lead to my next problem,i was driving in fourth gear,stomp the gas peddle (not to heavy)and low oil pressure lite came on (5 lbs) ,pulled over and pressure slowly climb back up.oil level at the dip stick is good.are these problems connected
any help greatly appreciated
Old May 22, 2011 | 01:53 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Battery voltage sounds normal..
The 5 VDC Reff voltage comes from the PCM and is used to supply a reff voltage to all the sensors. If that reff voltage is not being correctly supplied, your sensors will not be accurate. Read the reff voltage at a few of the sensors and see what it reading. If its going LOW, there are several things that can cause it:
Make sure your battery connection/s are clean and tight and if it were me,,, I would clean the contacts in my ignition switch!!
-C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
Old May 27, 2011 | 05:39 PM
99mikeb's Avatar
99mikeb
So, I replaced the battery,load test showed it was bad.Installed new one ,took it for a drive and ECL code 1635 came back with low oil pressure.Drop to 5 lbs. then slowly climb back to normal pressure.Does this code originate from the ignition switch.
I ready to change the oil pressure switch,if you think thats causing code.
PLEASE HELP
To Ecl code 1635 wtf
