12 volts
Old May 22, 2011 | 05:24 PM
alankb's Avatar
alankb
Default 12 volts
Looking for a 12 volt power source on drivers side interior. Was wondering if maybe the interior light was switched with the ground, leaving the hot wire hot. Also considering the brake light switch. Thoughts?
Old May 22, 2011 | 05:36 PM
c4cruiser's Avatar
c4cruiser
Remove the carpeted panel at the front of the passenger side footwell. In the upper right corner there are 3 unconnected wires; one is red, another is orange, a third is black.
The red wire is 12v that is always hot.
The orange wire is 12v switched (hot with ignition switch in the ON position)
The black wire is ground
The two power wires will handle a 10A load. Simply extend the wire you need thru the center of the dash to where you need it.
Old May 22, 2011 | 05:42 PM
lucky131969's Avatar
lucky131969
Well....at least you got the black wire right.....
The orange wire is : hot at all times.
The yellow wire is : switched.
http://forums.corvetteforum.com/1577389412-post4.html
Old May 22, 2011 | 08:26 PM
alankb's Avatar
alankb
Default thanks guys
Sure I can figure it out from here. Thanks!
Old May 23, 2011 | 09:52 PM
alankb's Avatar
alankb
Default Fyi
On my car, 2001, I finally found the blank yellow, orange, and black wires over against the tunnel.
To 12 volts
