Rocking Seat fix longevity
May 23, 2011 | 03:00 PM
I used this fix for the rocking seat problem:
http://www.lieblweb.com/c5seatfix.html
does anyone have any idea how long this should last? I would like to think that the Nylon washers that I used will be permanent fixes, but wasnt sure.
May 23, 2011 | 03:37 PM
The nylon will most likely fracture with age/use so I doubt it will last for more than a few years, especially if you move the seat a lot.
May 23, 2011 | 04:07 PM
St. Jude Donor '05-'06
mine is already loosening up after 6 mo.
May 23, 2011 | 07:16 PM
why couldnt you use metal washers the same way and just cut them to fit like the nylon ones?
May 24, 2011 | 09:09 AM
If the nylon ones fail, I will use aluminum and re-do it.
May 24, 2011 | 09:14 AM
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
May 24, 2011 | 11:05 PM
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
do a search for my "lazyman's fix for the rockin' seat"...much simpler way to go...
May 25, 2011 | 09:07 AM
I repair the rocking chair problem with steel washers. It takes longer to grind them down to fit properly, but I know they will last. Did my driver (98) four years ago and it's still okay. Make sure you use some good lube/grease on the worm gear. The wear on that and the aluminum block were my only concern with using steel. But, it's been four years and still okay.
