Lights not working
Old May 25, 2011 | 05:47 PM
Overlander's Avatar
Overlander
Default Lights not working
My 2002 C5 has been sitting for a while, so the battery had drained. After I started it with my trusty JNC-660 jump starter I noticed a new problem.
When I turn the **** to engage the headlights, they don't pop up. The interior dashboard & console lights become brighter as one would expect, but no headlights. Also when I unlock the vehicle with the remote, my reverse lights no longer blink, so I suspect they don't work either. I turned on the hazard light switch and the turn signals work fine.
Any ideas on what I should check? Do the reverse and headlights work on the same fuse?
Old May 25, 2011 | 09:59 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I think you should get the battery charged to full power then see how the lights are doing after that. The C-5 computers are a real issue when the battery is low.
Old May 25, 2011 | 10:42 PM
Overlander's Avatar
Overlander
Thanks for the reply dgrant. After jump starting, I let the car idle for over an hour, but when I tried to start it a few days later, the battery wasn't sufficiently charged to do so. Looks like I'll be getting a new battery and trying it after that.
Old May 26, 2011 | 04:44 AM
tim32311's Avatar
tim32311
Leaving the car running for an hour will not charge the battery sufficiently. You need to put it on a battery charger.
Tim
Old May 26, 2011 | 05:47 AM
dgrant3830's Avatar
dgrant3830
Tim
Its not going to charge it nearly enough
Old May 29, 2011 | 08:57 AM
Overlander's Avatar
Overlander
Thanks for the help. You guys were right, it was indeed the weak battery that caused the issue with the lights.
Old May 29, 2011 | 06:06 PM
dgrant3830's Avatar
dgrant3830
Thanks for letting us know...better to be right than wrong!
To Lights not working
