For a first time using an electric buffer
Old May 25, 2011 | 09:07 PM
bobby777's Avatar
bobby777
Default For a first time using an electric buffer
which one is fool proof safe to not destroy the clear coat? Just want a deeper shine--
Old May 25, 2011 | 09:13 PM
dougbfresh's Avatar
dougbfresh
No such thing as Fool Proof-practice on something you don't care about 1st! Dual/random actions are the safest but you can ALWAYS burn a paint job.
Old May 25, 2011 | 09:18 PM
Chris Stewart's Avatar
Chris Stewart
Porter cable 7424xp, the harder you lean on it the more it shines. Just keep the pad clean of rocks or debris.
Search Junkman on Youtube. His videos are great.
Old May 25, 2011 | 09:19 PM
bobby777's Avatar
bobby777
Well than that is not for me--thx. Ill stick with my hands for a show-car shine--
Old May 25, 2011 | 11:10 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
The Porter Cable 7424XP, as mentioned above is the best. If you watch the infamous Junkman vidoes he puts all of his body weight on the Porter Cable while it is on full speed and it doesn't hurt the paint at all. I would not hesitate to use it, at all.
Old May 26, 2011 | 06:28 AM
Florida99's Avatar
Florida99
There is always an orbital palm polisher which will help make things go faster, though not as professional as the Porter Cable or a polisher that is not orbital but no worries when using one.
Old May 26, 2011 | 07:42 AM
Paul 75 L82's Avatar
Paul 75 L82
I have the Porter Cable unit and used Mothers Power Polish and Mothers Power Wax. Both products are made for just that process and I was really happy with the results.
Old May 26, 2011 | 11:03 AM
tmatthews's Avatar
tmatthews
There is alot of good info on the Forum in general corvette section and
check out vendor "auotgeek.net" that also sells products along with alot of info.
Old May 26, 2011 | 11:54 AM
redrckt97's Avatar
redrckt97
I use a Griots Garage random orbital & think it would be Almost
impossible to burn the paint ... and its a nicely made machine.
Old May 26, 2011 | 12:01 PM
CROOZ1N's Avatar
CROOZ1N
Stay clear of Walmart type buffers though they are nothing more than wax spreaders and are pretty much a waste of money. The porter cable is the way to go along with good product lines to make her shine better than new.
Old May 26, 2011 | 12:43 PM
hotwheels57's Avatar
hotwheels57
You don't have to "lean" on the PORTER CABLE to achieve a great shine. Use the polish/wax/sealant of your choice with a variety of pads, and allow the machine to do all the work.
There is a detailing forum on the main menu page with lots of information to learn there.
Old May 26, 2011 | 06:07 PM
craig04c5's Avatar
craig04c5
I bought 2 cheap random/orbital buffer's a 6" and a 10" years ago. They work very well. I tested them on my wife's car to see what it would take to "hurt/burn" the paint. I held it on there for a couple minutes and no damage. I usually test on her car before using any polish, scratch/swirl remover, pads etc. Have yet to damage her paint and I also did it on high spots (edges and creases in the body) . I had a scratch on my bumper near the hatch and wet sanded very lightly then used my 6" buffer and held it on for 60 seconds at a time then put more polish on the pad. Did this 10 times until the scratch was no longer noticeable. I guess if you used a very aggressive cleaner/wax you could damage your paint but you would have to hold it on the paint for a good while. I would like to get a Porter Cable but for now my cheap buffers do a great job.
Old May 26, 2011 | 09:07 PM
lucky131969's Avatar
lucky131969
Originally Posted by craig04c5
.....I tested them on my wife's car to see what it would take to "hurt/burn" the paint.
Old May 27, 2011 | 11:31 AM
bobby777's Avatar
bobby777
I have chose to start with a 7 inch cheapie--the last thing i want is to burn thru the clear-coat--thx for all advise-
Old May 27, 2011 | 12:45 PM
sean.b's Avatar
sean.b
I got the Flex instead of the Porter Cable, but it's like comparing supercharged z06's to zr1's when you're buying that high end. I *read* the Flex is better, but it's all going to come down to the person doing the job. I have my flex, same compounds, and little practice, and cant do nearly as well as my buddy with his PC and a lot of practice
autogeeks.net has a ton of videos, promos, etc on polishing if you're interested in getting into it. and of course youtube has hundreds of people showing you how. in fact there's one guy that does c5's specifically.. some black guy with a southern accent, has very good videos.
To For a first time using an electric buffer
