What programmer to use? Are they worth it?
Old May 1, 2002 | 02:07 PM
F8LPONY's Avatar
F8LPONY
Default Re: What programmer to use? Are they worth it? (ToplessTexan)
I think it has some educational value (beyond the performance tuning value) for the hobbyist that wants to learn more about how their car works. It's not something that would interest the guy who gives his keys and a check to his tuner.
I completely agree. :)
If you are the latter then stick with an custom tuning or a powerloader. :D
Old May 1, 2002 | 02:08 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Default Re: What programmer to use? Are they worth it? (2000^C5)
Old May 1, 2002 | 02:12 PM
jawski's Avatar
jawski
Default Re: What programmer to use? Are they worth it? (C5XTASY)
Try a Hypertech III. Set it as follows:
2-3 shift +5 mph
[Modified by C5XTASY, 9:34 AM 4/30/2002]
:rolleyes: I think I'll try the + 200 RPM :rolleyes:
Old May 1, 2002 | 02:32 PM
silversport's Avatar
silversport
Default Re: What programmer to use? Are they worth it? (jawski)
I think you have helped me meake my mind up on this as well...I am going to stick with the stock program for now...my car has very little to nothing modded and until I decide to start doing that, I think the stock program is going to have to do... :chevy :seeya
Old May 1, 2002 | 11:54 PM
C5XTASY's Avatar
C5XTASY
:rolleyes: I think I'll try the + 200 RPM :rolleyes: [/quote]
What a strange post. :confused:
[Modified by C5XTASY, 9:56 PM 5/1/2002]
Old May 2, 2002 | 12:10 AM
C5XTASY's Avatar
C5XTASY
I'll offer the fact based observation :) that the HPP3 makes it's greatest changes in force motor current at intermediate throttle, less at high and low throttle (but still changed.)
I don't know why anyone would expect lower ETs or higher traps with *just* firmer shifts though. A firmer shift is not the same as a shorter shift.
Topless, I have a two part question that maybe you can explain to me.
1) I understand that a quicker shift can be had by changing the shift solenoid timing. That's a given. However, how much of a quicker shift are we talking about? I don't really have a feel for the time factor involved.
2) The HPP III adjusts shift firmness. Now, when pressure is increased, the clutches slip less and lock up quicker. Therefore, less time is spent at the shift with slipping clutches, thereby applying more power to the wheels sooner than without the increased pressure. If the total time spent disengaging and reengaging the clutches is less, thereby applying more power to the ground sooner, how can that not be equated to a "quicker shift"? The effect seems the same.
Ed
Old May 2, 2002 | 02:02 AM
ToplessTexan
Stock durations are around ~400-600ms. The 2-3 is the nasty long shift. I've shortened mine by as much as 200ms, though not across the board. You're right that increasing line pressure decreases clutch slippage and things happen faster, but something still has to start and stop the shift. It's really the shift duration table that defines these target durations. There are some adaptive transmission parameters (not unlike the fuel trims) that are used to fine tune line pressure based on recent shift durations and how far off target they are.
But don't take my word for it. :) You can always experiment w/ different firmness settings at the track and let your ET decide.
Old May 2, 2002 | 02:01 PM
jawski's Avatar
jawski
1 MPH = 200 RPM :D
Old May 2, 2002 | 09:50 PM
C5XTASY's Avatar
C5XTASY
1 MPH = 200 RPM :D
No wonder I didn't understand what you meant. With 3.15 gears, on the 2-3 shift, 1 mph=65 rpm, not 200 rpm. 200 would have meant I was increasing the shift point by 1000 rpm. :eek: I like my car a lot more than that! :D
Ed
Old May 3, 2002 | 11:03 AM
C5XTASY's Avatar
C5XTASY
Great info! Thanks! Two more things:
1) I probably should have said less clutch slippage DURING the shift, which I assumed would be a positive thing as far as applying more average power to the wheels during the shifting process. That's what my assumptions were based on. (Still seems to make sense to me. Oh well. :))
2) On the adaptive aspect of the transmission, regarding line pressure vs shift duration, does it "learn" out a line pressure increase (e.g. Hypertech, LS1.Edit, PLII, etc.) at part throttle, with WOT being an "Open loop" fixed setting, just as it does for fuel trims? What does it use for feedback; line pressure or shift duration?
I am impressed with the .2 second shifting time reduction on the 2-3 shift you were able to achieve. That's more than I would have imagined possible on one shift. What were you able to do on the 1-2 shift? Oops...I guess that's three things. :D
Thanks a lot! Later...
Ed
[Modified by C5XTASY, 9:05 AM 5/3/2002]
Old May 3, 2002 | 11:30 PM
C5XTASY's Avatar
C5XTASY
Old May 4, 2002 | 12:35 PM
ToplessTexan
The 1-2 isn't as bad, so not so aggressive there, maybe at most 100 ms.
The feedback is shift duration deviation, the response to it is line pressure adjustments. I wouldn't draw too many analogies with the fuel trimming system beyond the notion of a feedback based adaptive control system. My impression is that the fuel delivery system is necessarily more complex.
<soapbox>
I hate to see the term "learning" applied to adaptive control systems like this. Learning implies acquiring and utilizing previously unknown information. Since these systems simply adapt within well defined constraints (and :U otherwise) I'd hardly call them "learning" systems.
</soapbox>
We are way off topic again. :)
[Modified by ToplessTexan, 10:37 AM 5/4/2002]
Old May 4, 2002 | 12:58 PM
  #33
C5XTASY's Avatar
C5XTASY
<soapbox>
</soapbox>
Thanks for "learning" me to use the proper terminology!:D Have a good one! :cheers:
Ed
[Modified by C5XTASY, 11:00 AM 5/4/2002]
