Changing Thermostat/coolant question.
Old May 4, 2002 | 01:17 PM
QuickSilver2002's Avatar
QuickSilver2002
Default Changing Thermostat/coolant question.
I’m about to change my thermostat to a 178 later this afternoon. Is there any reason that I should not reuse the coolant that is in the car (it only has 2k miles on it). I just don’t want to waste good coolant or create pollution unless it is necessary.
Any other tips on the switch would be greatly appreciated.
Old May 4, 2002 | 01:32 PM
borba's Avatar
borba
Default Re: Changing Thermostat/coolant question. (QuickSilver2002)
I would keep the coolant that came with the car. That coolant is still good and as long as you do not contaminate the coolant with dirt or grease its will work great. I also added water wetter from Redline to help out the cooling process. Good luck! :D
