Differential fluid
Old Apr 21, 2002 | 11:34 PM
radstoy's Avatar
radstoy
Default Differential fluid
I recently changed the diff. fluid in my C5 to Amsoil plus GM additive. I wish to do the same with my Z28 but with Mobile 1. Word is that is a no-no as it apparently violates GM spec 9986115. No one seems to know what this specification is. Is anyone on the forum familiar with this issue? What are some fluids that DO meet the GM specs? I sure hope Amsoil plus additive does. Thanks for your help. Rad :confused:
Old Apr 22, 2002 | 12:10 AM
davidfarmer's Avatar
davidfarmer
Default Re: Differential fluid (radstoy)
I would think Mobil 1 would meet any GM standard, as they are pretty tight. The fluid requirements should be in your owners manual, and if appropriate fluids are readily available, contact your dealer. Let them figure it out.
btw, I like mobile 1 gear lube.
Dave
Old Apr 22, 2002 | 06:27 AM
vettenuts's Avatar
vettenuts
Why did you put in the GM additive? The Amsoil Series 2000 already has 5% additive in the oil as it comes from the bottle. Were you having a problem with it?
Old Apr 22, 2002 | 08:43 AM
IMQUIK's Avatar
IMQUIK
Amsoil meets spec for the Corvette :smash: And Camaro!
Leave it in, ask them to put it in on paper. :eek:
They will shut up then :D
[Modified by tshac, 12:50 PM 4/22/2002]
Old Apr 22, 2002 | 11:43 AM
radstoy's Avatar
radstoy
Default Re: Differential fluid (vettenuts)
I had previously discussed that issue with an Amsoil Distributor and he indicated he put the additive in his diff. I thought I should do the same. Rad
Old Apr 22, 2002 | 12:51 PM
vettenuts's Avatar
vettenuts
Was this the Series 2000?
Old Apr 22, 2002 | 01:46 PM
radstoy's Avatar
radstoy
I use Series 2000 but I don't remember what he used. :)
To Differential fluid
