pushrod question
Old May 27, 2011 | 08:34 AM
Blow Torch's Avatar
Blow Torch
Default pushrod question
Anyone know if I will still be able to use my 7.425 pushrods when I go from stock LS1 heads to 64cc AFR heads. Since I don't know how much AFR would have milled to get them 64ccc, I wasn't sure.
I don't have a checker :bang:
Old May 27, 2011 | 08:38 AM
chevy406's Avatar
chevy406
Buy the $20 adjustable pushrod and check after you install the AFR heads. Nobody can answer this question properly for you. And are you going to trust the opinion of a stranger on the internet to properly set up your valvetrain?
Old May 27, 2011 | 04:58 PM
99 vett babycar's Avatar
99 vett babycar
no one can Guess rod length, regardless what a couple of hundred guys on this Forum will tell you.
Old May 27, 2011 | 06:46 PM
Blow Torch's Avatar
Blow Torch
Just borrowed one from a local machine shop
The AFR 64cc heads and aftermarket cam are such a common setup, I had hoped someone had the information handy
Old May 27, 2011 | 07:06 PM
ZeeOSix's Avatar
ZeeOSix
Aren't the stock rods 7.400"? If the heads are milled, wouldn't you need a shorter pushrod.
Old May 27, 2011 | 07:23 PM
vettenuts's Avatar
vettenuts
No, they are 7.385" gauge length.
Old May 27, 2011 | 07:24 PM
vettenuts's Avatar
vettenuts
Check my posts on AFR heads, I needed to alter the rocker setup due to valve stem length. I would first check the wipe pattern, you may find it is way off.
Old May 27, 2011 | 08:32 PM
ZeeOSix's Avatar
ZeeOSix
Is the gauge length from tip-to-tip length? It seems there are different ways to define the length.
OP is saying he currently has 7.425" pushrods with use on stock LS1 heads. Something seems strange.
Old May 27, 2011 | 10:44 PM
Blow Torch's Avatar
Blow Torch
But I have an aftermarket cam with smaller base circle, so I need longer than stock
I used this method;
. Using the EO/IC method, get the lifter to the base circle of the cam.
2. Using a known length pushrod (7.400" is a good start with stock rockers) run the rocker arm bolt down to zero lash. This is easily done with your fingers "wiggling" the rocker, the point at which the "slack" is just gone is zero lash.
3. Set your torque wrench to 22 lb./ft. Tighten the rocker to full torque and count the number of turns it takes to get there. 1 full turn wtih a stock 8mm X 1.25 bolt is ~.047" preload as measured at the pushrod/rocker interface.
4. I normally shoot for 1 1/4 to 1 3/4 turns with stock type lifters like Comp 850's, LS1, LS7 etc.
For an example, if you use a 7.400" pushrod and come up with 3/4 of a turn, you will need at least .025" longer pushrod to get into range. If you end up with 2 1/4 turns, you will need one .025" shorter...
I might not know everything but I will tell you that this method has worked for me year after year cam swap after cam swap. We average 3 cam swaps a week here so you can do the math.
and using my 7.425s only have between 1/2 and 3/4 turn, so it looks like I will need a 7.45-7.475 if my calculations are correct.
I will use my checker tomorrow to verify
Old May 28, 2011 | 07:51 AM
SMaster's Avatar
SMaster
I had my L98 block zero decked. Stock was 7.2". With TFS heads and Comp. Pro Magnum rockers I would have been guessing a long time. In the end I ended up with 7.050 to get the geometry correct. I also had a pretty radical cam with a smaller base circle so I thought I'd need a longer pushrod but that still wan't the case.
Point is, yes, measure them with an adjustable tool and yes, I did need a MUCH shorter than standard pushrod because of the decked block and aftermarket heads.
Old May 28, 2011 | 08:23 AM
Blow Torch's Avatar
Blow Torch
Now the much argued "amount of preload" comes up
Some guys (veterans) are saying 1/2 turn is the quitest, others (veterans) are saying 1 - 1 1/2 is perfect.
More research
Old May 29, 2011 | 04:41 AM
SMaster's Avatar
SMaster
More research
I haven't even had the valve covers off my LS1 but on my stroked 350 TPI with Stealth Ram intake I set them at 3/4 turn past just moving the plunger off the seat. Of course I could see them before I put the intake on but got a good feel for them afterwards.
I had lifter pump up with the stock lifters limiting RPM's to about 54-5600 with TFS springs, Harland Sharp rockers.
After I went with Comp Cams lifters, dual 1.46 springs, Pro Magum rockers I could do 6400 which is where I needed to shift anyway. But, the lifter pump up was gone.
I've been reading about the LS1 here and preload but seems to me enough to make it run quiet should be enough.
To pushrod question
