DRL lights doesn't work after a car wash.
Old May 29, 2011 | 12:49 AM
c52korvette's Avatar
c52korvette
Default DRL lights doesn't work after a car wash.
Just as the title says.. is this common to any of you guys out there?
thanks for help!
Old May 29, 2011 | 02:12 AM
Tesseract's Avatar
Tesseract
You sir, have just joined the famous club called the, "You just literally exploded your DRL's to a carwash" club. Ok, I made that up but seriously, I'm posting this because not only was I a victim, I did it twice and it took me nothing short of a week to order replacement corner housings with LED's from JWM.
Check your corner housings. Wouldn't surprise me one bit if you have amber shrapnel bouncing around in there. This is common actually. The stock DRL bulbs are BRIGHT and HOT. They burn a small hole in your plastic light housing and that's where high pressure (not just rain usually) water goes. Cold water on hot bulbs... You can figure out the rest.
Buy replacements or I strongly recommend LED's. Trust me, this doesn't get better on its own. I have thin wrists so I was able to squeeze my arms down while the head lamps were up, to replace the bulbs. Hurts like hell but it's doable.
Be careful when pulling the bulbs. Seriously. They are actually shattered or have holes. So wear gloves.
I am sorry to hear you went through this. Trust me, I feel your pain.
Good luck!!!!
Old May 29, 2011 | 06:44 AM
k0ts's Avatar
k0ts
You can repair your current lamps... There will be a hole melted in the top of the
housing.. I used RTV (silicon) to plug the hole/holes.. I did both sides and then replace
the bad bulbs. It's cheaper than LEDs or new lamp housings. And not all that hard to do.
Old May 30, 2011 | 12:38 AM
c52korvette
Woah! thanks for all of your great input. I am going to try to fit my hands through that brake duct haha. Just to make sure.. May I know what type of parking lamp bulb it is and where I could get it locally? again..
Thanks.
Old May 30, 2011 | 04:53 AM
DeeGee's Avatar
DeeGee
Changing the bulbs wont fix it. The DRLs have burned the lamp housing. You need to fix the root cause.
Heres the full procedure for replacing the lamps. I'd go in through the floor for this job whereas I go in around the headlamps to change a bulb. If you get in there and find you can use sealeant all the better
Its a 4157NA bulb but a 3157NA will work.
Document ID# 655625
2002 Chevrolet Corvette
________________________________________
Park/Turn Signal/Side Marker Lamp Replacement
Removal Procedure
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2. Remove the front fascia lower closeout panel.
3. Release the brake caliper cooling duct from the front fascia, and position the duct aside.
4. Remove the front turn signal lamp bracket retaining spring from the lamp bracket.
5. Remove the lamp bracket retaining spring from the front fascia.
6. Remove the front turn signal lamp bracket retaining screws.
7. Disconnect the sockets from the lamp.
8. Remove the lamp, with the bracket, from the vehicle.
9. Remove the lamp to bracket retaining screws.
10. Remove the lamp from the bracket.
Installation Procedure
1. Install the front park/turn signal and sidemarker lamp into position on the front turn signal lamp bracket.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2. Install the front park/turn signal and sidemarker lamp to bracket retaining screws.
Tighten
Tighten the front park/turn signal and sidemarker lamp to bracket retaining screws to 2 N•m (18 lb in).
3. Install the sockets to the lamp.
4. Install the lamp, with the bracket, to the front fascia.
5. Align the lamp to the opening in the front fascia and hold the lamp firmly in place against the fascia, while installing the front turn signal lamp bracket retaining screws.
Tighten
Tighten the front turn signal lamp bracket retaining screws to 3 N•m (27 lb in).
6. Install the lamp bracket retaining spring to the front fascia.
7. Install the front turn signal lamp bracket retaining spring to the lamp bracket.
8. Position the brake caliper cooling duct to the front fascia and press the duct toward the fascia to secure.
9. Install the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
Old May 30, 2011 | 08:55 AM
Rockbridge's Avatar
Rockbridge
St. Jude Donor '11
Thanks.
Put 911 on speed dial on your cell phone and keep it in your free hand before you get started!
Old May 30, 2011 | 09:07 AM
sjc*2's Avatar
sjc*2
This is just a really bad design that needs to be corrected by each owner and not just keep replacing bulbs.
Go with the switchback LED's and fix the holes in the top of both corner housings. You will be shocked at the holes literally melted out of the housings. I used a small piece of aluminum sheet over the hole and then heat rated RTV sealant. Buy the LED's, hyperflash adapter and be done with this bad design by GM. They should have recalled this and I am surprised there were no fires from it. Maybe there was.....
Old May 30, 2011 | 11:48 AM
rebelheart's Avatar
rebelheart
I would use a small piece of sheet metal and some epoxy rather than silicone because of the high heat.
Old May 30, 2011 | 11:00 PM
c52korvette
SUCCESS! I have fit my hand through and changed the bulb. I found a spare light bulb in my garage it says its a 405A and it ended up working! =D so.. as of now it stays in the garage away from water till I have the time to patch up the housing.
Thank you all for great input. You have all helped me very greatly!
Old Dec 16, 2011 | 05:47 PM
Spatiality's Avatar
Spatiality
At first I just repaired the DRL damaged housing so the water from the car wash didn't leak inside the lens housing but then I figured what the heck and just ordered a set of new lenses fron Eckler's.
Old Dec 16, 2011 | 06:21 PM
TrueBlueCoupe's Avatar
TrueBlueCoupe
Looking at the design of the light, can't you just remove the housing from the bracket and leave the bracket bolted to the car, looks easier to me? Anyone do this? Pros/Cons
Old Dec 16, 2011 | 09:46 PM
Spatiality's Avatar
Spatiality
I don't really remember how hard it was to get to those two screws on the bracket but getting the two screws out the way the instructions outline is pretty easy to do.
To DRL lights doesn't work after a car wash.
